Re: celica surging
There are a few things that might cause this.
1: Check to make sure the vehicle is full of coolant, if the coolant is low, the IAC motor may not come off of high idle and when the TPS is showing the throttle closed with high rpm's, the ecu will go into fuel cut causing the 1000rpm-2500rpm engine speed shift as you described.
2: the IAC motor is malfunctioning
3: the TPS is malfunctioning
Have any codes stored?
25 yrs with TOYOTA
