Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Out-of-Production Cars & Vans
Old 08-24-2006, 04:52 PM
scooterwilli's Avatar
Dealer : Carter Toyota
- Other -
Last Online: 08-24-2006 07:24 PM
scooterwilli is on a distinguished road.
scooterwilli's Photo Albums
Default lookin for info on lifting my previa
hey there all...
been scouring the net for a week now looking for info on lifted previas. anyone out there got anything??? not lookin to sky jack it. i just an inch or two ta give me a little more snow clearance. looks like it might be kinda easy, for the front anyways. maybe just longer shocks?? i would rather stay away from body lifts as the springs for the front struts are in the way of putting bigger tires on... so i was thinking of coil over socks... if they come in a size i could use. the rear end is the difficult part...
any help or leads would be greatly apreciated....
scott
Old 08-25-2006, 07:30 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: lookin for info on lifting my previa
Originally Posted by scooterwilli View Post
hey there all...
scott
The rear is easy. You could have a set of custom springs made. They are not as expensive as you might guess.
I would call Coil Spring Specialties -- individually calibrated coil springs for any suspension need. and ask. Thats at least inexpensive to find out.
The front , you could have a machine shop fabricate some aluminum spacers to go ontop of the upper strut support, and replace the studs in the upper strut support with longer hardened bolts. This is a typical spacer lift for tundras/tacomas/sequoias. The previa strut is much bigger around in size, so the spacer would probably have to be custom made.
Just an idea
25 yrs with TOYOTA
Wheel/tire options on '06 Tundra DC without lifting qqqqqqqman Tires and Wheels 3 07-20-2006 03:25 AM
Alignment after lifting?!?!? HackSack Suspension & Axle 4 07-19-2005 10:48 AM
Are spacers good for lifting? jdeezylvn Suspension & Axle 4 08-10-2004 12:34 PM
seeking tundra lifting advise fyu Suspension & Axle 15 04-13-2004 07:51 PM
