Go Back   Tundra Solutions Forum > Cars & Vans Forums > Out-of-Production Cars & Vans
Unichip.com
Old 10-10-2006, 01:35 PM
Dealer : Beechmont Toyota
- Other -
Last Online: 10-11-2006 07:48 AM
The Fish Genius is on a distinguished road.
The Fish Genius's Photo Albums
Default 87 Toyota Van manual trans. clutch
Hey, new here, and desperate. I have an 87 Toyota Van, with a manual transmission. The clutch pedal will not disengage the clutch while the van is started. When not started, the van goes into gear but the pedal is still mush. It will take off - the wheels spin - if you start it in gear. But then won't shift.
I checked the clutch cable - it seems to be connected, but I don't know what else to check. I can't find a manual for it either, and the auto parts guys said maybe it's a hydraulics problem, and to look for a reservoir that may be low or leaking, but I can't seem to find one. Or any way to put fluid in it, period.
Any help you can give me is greatly appreciated!
George - The Fish Genius
Old 10-10-2006, 05:34 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Last Online: 07-02-2009 06:39 PM
Images: 153
mustang67408 is a splendid one to behold. mustang67408 is a splendid one to behold.
Default Re: 87 Toyota Van manual trans. clutch
There is no clutch cable. You probably felt the speedo cable.
It uses a hydraulic clutch master cylinder and a hydraulic slave cylinder.
Remove negative battery cable
Remove The instument finish panel (5 screws)
Remove combination meter (speedo head assy)
Remove air ducts #1/2/3/
Now you can see the clutch master cylinder, it gets brake fluid from the brake master cylinder. Look at the top of the clutch pedal is there fluid?
Look under the vehicle and find the clutch slave cylinder. Is it leaking?
Hope this helps
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
Old 10-11-2006, 07:48 AM
- Other -
Thanks so much! That makes sense... you're a Scooby Van Guru. http://www.tundrasolutions.com/forum...hanx_Smile.gif
Any advice on bleeding the clutch?
Thanks again,
George
Old 10-11-2006, 08:57 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 153
Thanks again,
George
Use a helper
1 pumps the pedal and keeps the fluid level up in the resovoir
1 opens the bleeder screw
Use a clear bottle and a small rubber hose on the vleeder screw on the slave cylinder (undervehicle)
If the system has a mush pedal as you describe , you probably need a clutch master and you might as well change the slave cylinder too.
If there are no leaks, you've bled the systemand the pedal still feels funny then the clutch pressure plate may have gone south.
Good Luck
p.s. YES, I remember these vans when new
24 yrs with TOYOTA
LinkBack to this Thread: http://www.tundrasolutions.com/forums/out-of-production-cars-and-vans/75454-87-toyota-van-manual-trans-clutch/
Posted By For Type Date
Re: Can't shift - Car Dealer Forums This thread Refback 02-06-2009 02:00 AM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 12:43 PM
New Tundra Incentive FireDevil Pricing and Dealers 5 08-31-2006 05:07 PM
Toyota Motor North America Names New Leadership Team nhparrot Toyota, Scion & Lexus News 0 05-09-2006 09:04 AM
Toyota Launches Literacy Program for Hispanic and Other Immigrant Families in Denver nhparrot Toyota, Scion & Lexus News 0 05-02-2006 11:35 AM
Toyota Environmental Update - Toyota introduces 2007 Camry Hybrid nhparrot Toyota, Scion & Lexus News 0 02-20-2006 02:04 PM
