Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Out-of-Production Cars & Vans
Old 10-18-2006, 03:33 PM
Dealer : Carlson Toyota
- Other -
Last Online: 03-21-2007 04:26 PM
yodoc40 is on a distinguished road.
yodoc40's Photo Albums
Unhappy 1992 Previa diagnostics check
Is there a way to check diagnostics codes without a code reader? I just bought a 1992 Previa and have never worked on a Toyota(This is my first). I wasn't happy to find out that the wiper blades are a dealer only item that runs approx $39.00. What other problems should I expect?
Old 10-19-2006, 12:17 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: 1992 Previa diagnostics check
Flip up the drivers seat.
The diagnostic check connector is under it.
Jump across pins E1 & TE
Turn ignition ON ( do not start)
The engine light will flash and you have to count the number of flashes.
This number of flashes is the "CODE"
Typical codes are for EGR, TPS, THW and THA
Run the codes and post, we can then assist you further.
The SADD shaft (equipment driveshaft) Is known for failing ($900)approx.
The mufflers develop a whistle sometimes. The header pipes rattle sometimes.
Oil pan level sensor fails.
They go thru front brakes if the rear brakes are not properly adjusted.
Dont let this scare you.
Overall, they seem to be a good vehicle, and last for hundreds of thousands of miles if properly cared for.
25 yrs with TOYOTA
Old 10-19-2006, 03:35 PM
- Other -
Thank you. I'll do as you suggest as soon as it is warm enough to do so. I HATE MINNESOTA!!!!
Old 10-26-2006, 10:11 AM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
change the diff fluid on a regular basis. i have replaced two units in the last two months. over the years, i have had to replace the diff on everyone of these i have worked on. mr mustang gave you a nice list of issues that are right on the money. yspert
Graduated from Y to Z status.
DIY: Check the Automatic Transmission Fluid Level nhparrot Engine & Drivetrain 47 11-30-2008 09:45 PM
How to check the trans fluid?? tundra.gator Engine & Drivetrain 3 02-02-2003 07:16 PM
Checking Auto Trans Fluid deanaddy Engine & Drivetrain 3 01-18-2003 12:45 PM
check engine/ fipk mehaffydr Engine & Drivetrain 5 11-07-2002 05:31 AM
