Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Out-of-Production Cars & Vans
Old 12-06-2006, 02:58 PM
Dealer : Ralph Hayes Toyota
Last Online: 10-17-2009 03:45 PM
RunnerBiker is on a distinguished road.
RunnerBiker's Photo Albums
Default Antenna Replacement - '95 SC300
I noticed that the antenna on my 1995 SC300 was not extending all the
way like it used to. It is the original mast. It still goes up and
down when it should, it just doesn't go all the way up anymore.
I assumed that a new antenna mast would let it extend fully again.
I bought an official LEXUS replacement mast. (I always use official
manufacturer parts on my Lexus and Toyota cars)
I removed the cap nut on the mast, and then removed the plastic spacer
at the fender.
With the key in the ignition and in the LOCK position, I pressed and
held the [AM] and [CD] buttons on the stereo. (This "magic" is
supposed to eject the antenna.)
I turned the key to Accessory.
The stereo display showed "AnT".
The antenna went up, but the antenna mast did not eject. It didn't go
any higher than it did when I turned the radio on in normal
conditions. It didn't sound like it was straining to push the antenna
out.
Have I missed something, or do I have to disassemble the automatic
antenna mechanism?
Thanks for your help.
Ken - West Union, SC Population 270 + 2 (counting dogs and chickens)
"If you only have a hammer, you tend to see every problem as a nail."
- Abraham H. Maslow
RunnerBiker
Old 12-06-2006, 05:13 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: Antenna Replacement - '95 SC300
at the fender.
out.
antenna mechanism?
- Abraham H. Maslow
Here are the LEXUS instructions for removal
When the antenna comes up, you have to give it a small tug to release it from the drive gear. It doesnt just "ejct on its own".
You might have to dis-assemble the motor to remove any broken piece of cable. If you dont remove this piece it will jam the motor upon re installation of the new mast. The cables usually break and that is why they dont go up as far as normal.
The cable once removed should come to a taper on the end of it. If there is no taper then the cable has broken. Abent antenna mast will also make it no come up as far.
25 yrs with TOYOTA
Old 12-06-2006, 05:39 PM
Thanks for the reply Mustang.
I didn't say it in the original posting, but I pulled as hard as I could to get the antenna to release.
I can't remember where I read it, but I thought I read that the radio was supposed to eject the antenna by itself. That is why you press the "magic" [AM] and [CD] buttons.
Since the antenna still goes up and down and radio reception is still good, I'll just wait until it won't go up at all and then I'll disassemble the motor to get the broken pieces out.
I have done it before on other Toyota power antennas.
I just wanted to make sure I hadn't skipped any steps. Your photos showed that I was doing it correctly.
I guess there is a disassembly in my future.
Thanks again.
RunnerBiker
LinkBack to this Thread: http://www.tundrasolutions.com/forums/out-of-production-cars-and-vans/81504-antenna-replacement-95-sc300/
Posted By For Type Date
antenna removal sc300 - Zuula Search This thread Refback 04-22-2008 06:10 PM
99 4runner antenna replacement, HOW? Begal 4Runner 2 07-08-2009 11:19 AM
98 4Rnr SR5 Auto Antenna Replacement czarny 4Runner 6 10-11-2006 02:20 AM
Power Antenna Mast Replacement Problem dsquare 1Gen-Sequoia 2 08-06-2006 03:30 AM
Replacement antenna for '99 4Runner shiles 4Runner 4 12-31-2004 07:44 PM
Antenna TSB nhparrot Audio & Stereo 0 03-28-2002 02:00 PM
