Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Out-of-Production Cars & Vans
Old 02-24-2007, 05:41 PM
Dealer : Leesburg Toyota
2000 Toyota Celica
Last Online: 10-12-2007 01:44 PM
whjacobs is on a distinguished road.
whjacobs's Photo Albums
Question Celica GTS Tensioner Replacement
Hello Members, this is my first post to a forum. I've run into a squacking drive belt tensioner that has given me some really flaky symptoms. The intermittant metal grind is particularly upsetting, especially after already replacing a perfectly good water pump before a read the Edmund's 2000-2002 test results. I have less than 1/2" between bolt head and frame. Is this enough room to remove the bolt replace the tensioner?
Old 02-25-2007, 04:48 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: Celica GTS Tensioner Replacement
No there is not enough room, to remove the bolt on a GTS(2ZZ). If it were a corolla (1ZZ) you'd have it alot easier.
You have to remove the front engine mount(passenger fender) and lift the engine with a floor jack under the oil pan (CAREFULLY, use a piece of wood between the jack and pan).
It is a pain in the drain.
25 yrs with TOYOTA
Celica GTS Tensioner Replacement whjacobs Out-of-Production Cars & Vans 0 02-24-2007 05:23 PM
1989 Celica Gts Heater tedm Out-of-Production Cars & Vans 3 12-02-2006 10:12 PM
Celica Replacement Salty_Dog Out-of-Production Cars & Vans 5 05-18-2006 04:39 PM
INFO:Tacoma Engine Oil Replacement Reminder nhparrot Knowledgebase Archive 0 02-03-2005 11:37 PM
Broken Belt Tensioner! SSparks Engine & Drivetrain 8 01-21-2003 12:00 PM
