Re: Clicking sound coming from engine
The owners manual specifies a valve clearance check every 60,000 miles. Failure to check and adjust the valves is a major cause of exhaust valve burning on the 3.0L V6.
Exhaust valve burning, in turn, is a major reason many 3.0L V6's end up in the junkyard.
Only the valve covers need to be removed to adjust the valves. The complicated part is that alot of other stuff must be removed in order to gain sufficient room to remove the valve covers and check the valve clearances.
