Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 10-01-2007, 10:14 PM
1994 Toyota Truck t100,
1999 Toyota Sienna ce,
2006 Toyota Tundra dc sr5
Last Online: 11-18-2009 08:58 PM
loytotoy is on a distinguished road.
loytotoy's Photo Albums
Exclamation Rear Break Question
My 94 was making some rear break noises so I got some new shoes for them. It so happened that when removing the drums that I noticed a lot of dirt and rust but the shoes definatly did not not to be replaced at 135k. So my friendly mechanic just cleaned the break parts: While doing this we noticed that if I put my foot on the break the pads did not move. Also if I loosened the nipple the line would not bleed. Whats up here? Can someone explain what is suppose to happen to the rear breaks when the pedal is applied?
Old 10-26-2007, 04:37 AM
Dealer : Bert Wolfe Toyota
2006 Toyota 4Runner Limited 4x4,
2003 Toyota Camry,
2007 Toyota Tundra 4x4 Limited "Slate"
Last Online: 11-10-2009 09:56 PM
leecpdk9 is on a distinguished road.
Send a message via MSN to leecpdk9 leecpdk9's Photo Albums
Default Re: Rear Break Question
This has to do with the load proportioning valve. Once the wheels are on the ground you will be able to bleed the brakes. and also see the shoes move, but i would not do this with the drum off
Old 09-25-2008, 10:14 PM
Dealer : Lake Charles Toyota
1994 Toyota Truck,
2006 Toyota 4Runner,
- Other - 74 Triumph TR-6,
1995 Toyota Avalon
Last Online: 10-12-2008 02:42 PM
cc1471 is on a distinguished road.
cc1471's Photo Albums
I had a problem with my rear brakes on my 94 extended cab p/u. I went to stop and I almost rear ended a caddy. I replaced the brake master cylinder/ brake booster and all the soft brake lines and bled them with a vacuum bleeder. still did not fix so I brought it to a mechanic who replaced the front brakes and then found out that the rear proportion valve had an anti skid? design. it had an arm that attached to the frame and went to a piston in the valve. if the truck would start to lean to the side (like when the rear brakes would lock up and the rear end would swing around) it would push the piston in and relieve the pressure to the rear brakes which would let them release. what he found was the old valve had corroded and froze with the piston shutting off the rear brake line. he replace it and now good as new. he also said that the rear brake pads looked brand new and were still good. in the 32 years he had worked as a mechanic that was the 2nd one he has had to replace. hope it helps.
Old 10-01-2008, 02:03 AM
Dealer : Star Toyota
1998 Toyota T100 SR5 2WD auto,
1996 Toyota T100 4cyl auto,
2001 Toyota Camry 4cyl auto moon roof,
- Other - 1985 Celica GTS conv
Last Online: Yesterday 05:40 PM
BamZipPow is on a distinguished road.
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow BamZipPow's Photo Albums
The proportional valve is a Load Sensing Proportional Valve (LSPV). It's dependent on the amount of weight you put in the bed or needs to be readjusted if you put on a lift. As the bed gits closer the the axle, the connecting rod closes the distance in the valve. As you press on the brake, the valve rod extends out to contact the connecting rod and this will increase the amount of brake fluid (pressure) to the rear brakes. The anti-skid portion should be in the engine bay if you have this feature. Follow yer brake lines from the master cylinder and you should find the anti-skid device if you have it. My 1993 T-100 has one that has the power steering fluid going through it.
I had to smack the crap out of mine on the outside with a 2x4 to break any crap inside of it free. Mine was not allowing enough pressure/fluid through it as well. I jacked up my differential and could spin my tires and jam on the brakes. The tires would still keep rolling!
I've been looking fer a spare one to tear apart so I can show people what it's made of and what servicing you can do to them. Anyone got one lying around that they don't want?
Rear end clunk question... Brian's Toy Engine & Drivetrain 29 09-29-2007 01:06 AM
Rear Tundra Lift Question TundraCrazy01 1Gen-Tundra 5 02-24-2006 02:38 AM
Group dyno run results v8Toilet Off-Topic 82 10-23-2005 11:44 PM
Rear Shoe wear question pcosens Brakes 9 06-20-2005 11:51 PM
V6/V8 rear axles the same? Question about adding l/s to V6 Tundra John97 Tires and Wheels 4 10-21-2003 05:38 AM
