Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 01-16-2009, 10:00 AM
Last Online: 01-16-2009 04:56 PM
ace233391 is on a distinguished road.
ace233391's Photo Albums
Default Truck just won't start
I'm buying a '97 T100 from my in-laws. The truck has been sitting outside for the winter, and had a completly dead battery. So I bought a new one, installed it, and there still isn't anything. The hazards and the headlights work, so I know that there is a connection - but nothing else works: the dash lights, the radio, it won't turn over or even click when I try to start it.
I checked the fuse box in the cab and under the hood but could not find any broken or missing fuses - does anyone have any ideas as to what the problem could be?
Old 01-24-2009, 11:52 PM
Dealer : Star Toyota
1998 Toyota T100 SR5 2WD auto,
1996 Toyota T100 4cyl auto,
2001 Toyota Camry 4cyl auto moon roof,
- Other - 1985 Celica GTS conv
Last Online: Yesterday 05:40 PM
BamZipPow is on a distinguished road.
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow BamZipPow's Photo Albums
Default Re: Truck just won't start
Could be a bad ignition switch? Do you have a multimeter? Check fer power at the main fuse (100amp?) under the hood. Does this have any kind of alarm system on it?
Old 01-25-2009, 10:15 PM
rx7vert's Avatar
Drunk Redneck
Dealer : Bert Allen Toyota
2003 Toyota Tundra
Last Online: 10-29-2009 11:49 PM
Images: 6
rx7vert will become famous soon enough. rx7vert will become famous soon enough.
rx7vert's Photo Albums
Also check the grounds. A loose or broken ground could cause it. Just a guess
Old 01-28-2009, 02:39 AM
2007 Toyota Sequoia Limited 2WD
Last Online: 03-19-2009 02:05 PM
carlosgv1 is on a distinguished road.
carlosgv1's Photo Albums
Yes, sound like a bad ground or bad positive + contact, check grounds and check Bat. Cables + and - can have (sulfates) inside the cables, looks like a white powder, if you find to much it's better to change cables.
Check for rust bolts, where hold the Negative - cable to the chassis, transmission or body. clean surfaces or change bolts.
Old 02-05-2009, 09:48 PM
Dealer : Street Toyota
2003 Toyota Tundra,
1995 Toyota Camry
Last Online: 11-04-2009 07:22 PM
leelemmon is on a distinguished road.
leelemmon's Photo Albums
Could also be a dead starter. It's not to hard to pull and have tested. I had the one on my '95 T100 rebuilt for about $80 and it only took about 4 hours to have done. It's not to hard to remove, but it is easier to jack up the front end so you have more elbow room. It's on the passenger side of the engine and you'll need an extension and a universal adapter. Pretty easy to remove and replace.
'03, SR5 Access Cab, Salsa, Charcoal Int, 4X4, V-8, Toyota Lid, Westin Nurfs, Hood Protector, Front Tint, Drop In Liner
