Go Back   Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 04-24-2009, 06:58 PM
Last Online: 05-16-2009 04:41 PM
coastmetal is on a distinguished road.
coastmetal's Photo Albums
Post Question Answered
Ten Characters
Old 04-24-2009, 11:45 PM
Dealer : Star Toyota
1998 Toyota T100 SR5 2WD auto,
1996 Toyota T100 4cyl auto,
2001 Toyota Camry 4cyl auto moon roof,
- Other - 1985 Celica GTS conv
Last Online: Yesterday 01:42 PM
BamZipPow is on a distinguished road.
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow BamZipPow's Photo Albums
Default Re: T-100 Ride Height?
What size tires and rims do you have? What does the distance between the front bump stops look like?
When it stops raining...I'll be able to run out and check mine fer yah. I have Yokohama Geolander A/T-S LT235/75-R15 tires and I know that the distance from the ground to the body (right behind the mudflap) is about 14" on the left side and about 15" on the right. My bump stops are about equal distance. I'm gonna have to turn the torsion bar a bit to balance the truck out.
Old 04-25-2009, 06:40 PM
Default Question Answered
Ten Characters
Old 04-27-2009, 02:09 AM
L f = 31 1/2" - r f = 32 1/4"
l r = 31 3/4" - r r = 32 1/2"
Old 04-27-2009, 09:08 AM
Oh...you can also crank the torsion bars down if it's too high. Also, check to see if they have a body lift or ball joint spacer...
Ball joint spacers...
2WD Ball Joint Spacers...
Old 04-30-2009, 10:19 PM
Ten Characters
Old 05-04-2009, 12:44 PM
Originally Posted by coastmetal View Post
It appears that the front end is 1" higher and the rear end is 2" higher than your measurements.
Definitely no ball joint spacers.
Doesn't the torsion bar only control the front end height?
CM
Yes, the torsion bar only controls the height of the fronts. Piccies of the underside would really help. Maybe they put in an AAL (add-a-leaf) to the rear leaf pack. They could've added a shackle kit...but without piccies I can't see to tell.
Old 05-06-2009, 04:09 PM
Ten Characters
Old 05-06-2009, 08:55 PM
That looks about right fer the height. With my camper shell on and tools in the back...the height between the axle and the rubber stop is about 3.5". So I'm guessing that the height yer showing is with nothing in the bed. The 2WD leaf pack is supposed to be 4 leafs which you show.
What's the size on the rims/tires? Cause I can't even stick my fingers in between the rim and the backing plate at all and from yer piccies...there's a lot of space in between there.
Tire sizes from the stock 15" rims:
Plus Zero
225/75-15
255/70-15
265/70-15
30/950-15
31/1050-15
32/1150-15
Plus One
265/75-16
275/70-16
285/75-16
Plus Two
255/65-17
Old 05-06-2009, 09:41 PM
Ten Characters
Old 10-29-2009, 01:50 AM
Last Online: 11-01-2009 09:35 PM
Frasier000 is on a distinguished road.
Frasier000's Photo Albums
yes, of course!
