Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 05-14-2009, 08:57 PM
Last Online: 05-18-2009 11:10 PM
bbarnhart is on a distinguished road.
bbarnhart's Photo Albums
Default 22 r e Interferance Motor
My timing chain broke while driving down the freeway. How can I tell what damage was done? Do I have to tare the hole motor down. What type of damage am I looking at?
Old 05-14-2009, 09:16 PM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
Exclamation Re: 22 r e Interferance Motor
valve damage.
check the valve adjustment. bent valves have very large gaps.
you will have to remove the head and timing cover.
yspert
Graduated from Y to Z status.
Old 05-15-2009, 06:40 PM
Default Re: 22 r e Interferance Motor
What if I don't have any large gaps. Should I then install a new chain and see what I have or should I just pull the head?
Old 05-15-2009, 08:17 PM
yspert's Avatar
hummmmm "no large gaps" means???? if you feel
or know that the clearances were pretty much "on"
before the chain broke, then check them and you
will know. the higher your rpm's when it lets go, the
more valves you will bend. so if you assume you didn't
bend all of the valves, then when you check them, you
will see: 10, 10, 18, 10 for example. then i would say
you have one bent. i also use a leak down test and
a scope to look at the valves and pistons for "tap" marks.
yspert
