Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 10-15-2004, 11:24 PM
Last Online: 10-19-2004 11:52 PM
Rusty80 is on a distinguished road.
Rusty80's Photo Albums
Unhappy 1980 Toyota P/U, Carb Problems
Hey everyone!
I bought a 1980 Toyota SR5 P/U (2wd, 5spd, 20R engine) from an Auction Sale about a month ago. It was taken or abandond by the previous owner so the history is unknown, it passed the local inspection with only some patching of rust.
My only problem is, when i got it, i put a battery and 10bux worth of gas in the tank, tried to start it but to no avail. Ended up being that the needle was stuck in the carb, few taps with a hammer and it was running in no time! It ran great but seemed to idle very very ritch and when i shut it off hot i couldnt get it started unless i held my foot to the floor and cranked it for about 2mins. Turned out not to be the Choke (has the water heated choke on it) so i figured a good carb re-build is in order. Picked up a Kit for the carb and installed it after cleaning everything so it was spotless. put it all back on and I have no clue where the vac lines go "DOH" no vac diagram i cap off all of the ports and start the truck up. well needless to say i have the same darn problem ecept for now it doesnt want to idle. no vac. leaks (will pull 19" of vac.)
Runs extreemely ritch (i changed the oil, havent drivin it more than 5miles, messed around with the carb, etc and it reaks of gas so i have to change that again. It seems to leak gas down the intake when shut off (this is my guess b/c its hard to start) i have the float level so the gas is half way up the sight glass in the carb.
I'm to my whits end on this one, this is my first toyota (used to playing with BigBlock Mopars and Holley Carbs).
Old 10-16-2004, 12:50 AM
tr4a's Avatar
Dealer : Toyota of Kirkland
2002 Toyota Tundra,
2006 Toyota 4Runner
Last Online: 11-08-2009 07:08 PM
tr4a is on a distinguished road.
tr4a's Photo Albums
Runs extremely rich (i changed the oil, haven't driven it more than 5 miles, messed around with the carb, etc and it reeks of gas so i have to change that again
I had a 81 P/U and it had a different carb problem sometimes would not idle. Low speed idle jet was getting plugged with rust I think.
You said the oil smells like gas. It might be that the fuel pump is leaking and pumping fuel into the crankcase. It's mounted on the top front of the engine.
Old 10-16-2004, 10:17 AM
wylcat's Avatar
DIRT BAG
Dealer : Sparks Toyota
2002 Toyota Tundra,
2000 Toyota 4Runner
Last Online: 11-15-2009 09:01 PM
wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence.
wylcat's Photo Albums
Default How to fix an early 80's Toyota carb:
how to fix an early 80's Toyota carb:
step 1: position vehicle on a steep incline.(be sure to make sure thre are no obstructions around vehicle)
step 2: remove lic. plate bolts, and lic. plate(put aside until step 6.
step 3: release parking brake and give it a nudge.
step 4: call insurance co.
step 5: use insurance money for new Toyota
step 6: reinstall lic. plate on new Toyota.
good luck with the replacement
HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
Old 10-19-2004, 11:16 PM
I think i've figured out why its running so rich and it must be tied in with the idle situations. When the truck is shut off you can see gas leaking down the secondary thottle bore (literally kind of like a streem all the way down the bore onto the blade and slowly leeking form there into the intake)
now i'm "figuring" that must be either comming from a Warped carburator main body or from the boosters some how.. are there supposed to be any check valves (little ball bearings in any of the booster holes?)
hmmm any thoughts on this? i'm tempted to say screw it and either buy a new "rebuilt" carb (at the very pricey expense of 288bux plus tax, keep in mind thats cdn) or make an adaptor to mount a 2bbl Carter BBD or Holley 2210 onto this intake (not something i have the time for)
Old 10-19-2004, 11:50 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
PM sent ...
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
Toyota Engine Problems sal minella Engine & Drivetrain 6 08-30-2007 07:54 AM
** Real Story on TRD S/C!! ** taco Engine & Drivetrain 593 10-27-2005 12:32 AM
Where's the beef, Toyota? fineride Engine & Drivetrain 8 12-31-2003 11:53 AM
