Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
  1 links from elsewhere to this Post. Click to view. #16 (permalink)
Old 10-14-2007, 11:22 AM
Dealer : Piercey Toyota Scion
- Other -
Last Online: 10-14-2007 11:22 AM
steelgtr is on a distinguished road.
steelgtr's Photo Albums
Default Re: Engine oil in coolant-22R
Hi Guys
Just found the forum. My 91 P/u (230,000, 22R, 5 speed) has also been going through coolant for a while without any other symptons. On Friday, it got hot (middle of temp gauge) and I couldn't keep coolant in the overflow. Yesterday I pulled the cap and there was the goo in the coolant and worse, there was the "mud" on the dipstick.
Could it be just a gasket or ??
thx
bob
  #17 (permalink)
Old 11-16-2009, 10:54 AM
Last Online: 11-16-2009 11:09 AM
00integravtecgsr is on a distinguished road.
00integravtecgsr's Photo Albums
I have the same issue. My friend brought his 95 P/U over. Said it got 3/4 the way hot, he pulled over and there was coolant in the oil. He had it towed to the shop and they #1 & #4 pistons were steam cleaned and that it would need a new engine. It has 330,000 miles on it.
I did a compression test on it the results were 180 psi in all the cylinders (engine cold obviously).
Now after reading this thread, it looks like maybe I have a crack in the exhaust ports on 1 and 4. Is that correct? Would a machine shop be able to check the head for cracks?
Also, I think I might have the timing chain issue as well. I will check that later today when I start tearing it apart to find out.
But any help would be great. Would it be worth fixing or just find a used motor?
  #18 (permalink)
Old 11-17-2009, 03:58 AM
Dealer : Star Toyota
1998 Toyota T100 SR5 2WD auto,
1996 Toyota T100 4cyl auto,
2001 Toyota Camry 4cyl auto moon roof,
- Other - 1985 Celica GTS conv
Last Online: Yesterday 08:53 PM
BamZipPow is on a distinguished road.
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow BamZipPow's Photo Albums
Check the timing chain guide and timing chain cover...slack in the chain may have eaten through the timing chain cover.
You can find new aftermarket timing chain covers fer cheap on ebay or the commercial vendors like AutoZone, RockAuto, etc...
The 22R/RE are easily rebuilt...yer gonna have to check the heads. Are you sure the radiator didn't crack and lose coolant through that?
  #19 (permalink)
Old 11-18-2009, 10:47 PM
slamdyota's Avatar
Last Online: Yesterday 10:54 PM
slamdyota is on a distinguished road.
slamdyota's Photo Albums
Hey guys. SOld my 07 tundra and last week purchased a 90 x-cab, 3.0L v-6 with 84,000 miles. Truck had not been serviced in about 10 years. Anyway, i experienced exactly what you all have been discussing. Didnt think the 22R experienced these issues, but the 3VZ is infamous for it. Dealers actually replaced first head gasket free, but the gaskets were usually not of new design. My probs started with gunk in overflow, no water in the oil but radiator looked bad. Started it up monday, white smoke/steam coming from exhaust pipe, and radiator emptied, overflow filled with oily looking crap. Took motor apart today, head gasket had swelled tremendously and was leaking badly. No outside signs of leaks on the ground though, all interior leaking. Oil looked like a YooHoo. Getting this all done by a good buddy of mine who has done over a 100 of the 3VZ headgaskets so he will get it right. Also doing water pump, thermostat,timing belt kit, head bolts, all gaskets possible, maybe a new radiator but it really doesnt look so bad. Tomorrow the heads come off, and i should have a little more info on the engine condition. This motor had the free replacement head gasket done, but it was done poorly.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/out-of-production-trucks-and-suvs/48222-engine-oil-in-coolant-22r/
Posted By For Type Date
Engine oil in coolant-22R - Tundra Solutions Forum This thread Refback 08-27-2009 03:23 AM
Engine oil in coolant-22R - Tundra Solutions Forum Timing chain wearing through This thread Refback 08-02-2009 07:45 AM
Anyone know how to 'unfreeze' an engine coolant plug? simon barsinister Engine & Drivetrain 4 08-22-2005 05:20 PM
Engine oil cooler and trans oil cooler installed keninsb Engine & Drivetrain 10 06-22-2005 03:50 PM
accidently drained my transmission oil then added more engine oil, what should i do? bLaM139 Engine & Drivetrain 13 02-12-2005 12:16 AM
Well, it's the oil..... akauth Engine & Drivetrain 9 06-12-2002 07:32 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
