Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 10-29-2005, 09:06 PM
cnold's Avatar
Dealer : Joe Machens Toyota
2005 Toyota Tundra
Last Online: 11-20-2009 08:21 AM
Images: 2
cnold is on a distinguished road.
cnold's Photo Albums
Default Engine oil in coolant-22R
My wife purchased a 1985 Toyota truck fifteen years and 220,000 miles back. The previous owner mentioned that a problem with the cylinder head and/or gasket was corrected under warranty but gave no further details. Recently, oil has shown up in the coolant and the cooling system is loosing fluid but there are no apparent leaks. I seem to remember that it was a common problem but can't find a reference to a service bulletin. Can anyone remember the proper repair procedure? The truck is still in good condition and if it can be fixed with just a head gasket and new head bolts, we would like to have it fixed to haul things that I wouldn't haul in my new Tundra.
Craig
Missouri
2001 Tacoma SR5 AC 4X4 TRD
2005 Tundra SR5 AC 4X4 TRD
http://ipics.iland.net/cnold113/main.php
Old 10-29-2005, 11:29 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
I would check the timing cover on the inside. When the timing chain guides break, the chain rubs the inside of the timing cover and rub a hole into the water jacket. Most people think that its a blown headgasket. Aftemarket water pumps also may wear a hole in the timing cover from the impellers rubbing thru. I always recommend factory timing components and a water pump.
If you pull the valve cover and look down the the chain. Apply pressure to the cooling system and you might see the leak. If if is a small leak i would suggest pulling the water pump and timing cover and inspecting closly.
22r's were not known for any coolant problems, unlesss they were overheated serverly, they crack in the #4 exhaust port and require a new cylinder head. Other than that i would bet my money on the thiming chain rubbing thru the cover, most people miss it,it looks like 2 grooves worn into the side of the cover.
Good Luck
Victor
25 yrs with TOYOTA
Old 10-30-2005, 07:04 AM
cnold's Avatar
2005 Toyota Tundra
Images: 2
Thanks for the tip Victor, but in this case, I see engine oil in the coolant but no coolant in the oil. The oil pressure being greater than the pressure in the cooling system, leads me to believe that there must be a one-way leak between the two systems. I assume that there is an oil passage through the head gasket to oil the camshaft. The loss of coolant is not enough to be visible at the tail pipe but could very well be a crack at the #4 exhaust port and unrelated to the other problem.
Craig
Missouri
Old 10-30-2005, 11:21 AM
Buzzard's Avatar
Dealer : Gulf Coast Toyota
2006 Toyota 4Runner
Last Online: 11-25-2008 05:44 PM
Buzzard is on a distinguished road.
Buzzard's Photo Albums
Good Luck
Victor
When you start the engine cold ---do you hear a noise for a couple of seconds? If you do check the timing chain tensioner --it is operated by oil pressure. It has a check valve that holds oil pressure on the pully. If this check valve fails it will let the chain rub the housing at start up. This will wear a hole in the housing. Dont thinlk it has anything to do with the coolant in the oil but if you check the chain look at this too. ----Buzz
Old 10-30-2005, 11:37 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Your right, if i would have opened my eyes and read what you stated "oil in coolant", i would have seen that. Oil pressure is greater that the water pressure. sorry, my mistake.
Is it for sure engine oil, or could it be trans fluid (if it's a ATM)?
Engine oil could have come from a cracked cylinder head yes. The heat from the xhaust in the cylinder head may be vaporizing the coolant and thats why you dont see it. Later model 22re's were notorious for leaking small amounts of coolant down the left side of the block, and under the intake manifold. there is a water pipe and a special square "O" ring under there to seal it.
The oil pressure feed for the cylinder head is on the left side of the block.
Let us know what ya find.
25 yrs with TOYOTA
Old 10-31-2005, 12:11 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: Yesterday 02:52 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
Default Blown Head gasket
Its a blown head gasket.(NOT) You are not seeing any coolant leak because it is being burned off internally. I would just take it in and have it checked. We have a special tool which looks sort of like a turkey baster that hooks up where the radiator cap goes and can detect exhaust in your coolant which will tell if the head gasket is blown. Easy to check. The timing chain issue only happens if you ignore a noisy timing chain for a good amount of time. FYI- Running 20w50 oil in the 22r's will help the timing chain last longer.
I was wrong. It sounds like it is the TC cover. OOPS.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 12-22-2005, 06:04 PM
Last Online: 09-14-2009 10:29 PM
swanng is on a distinguished road.
swanng's Photo Albums
I recently rebuilt the 22R in my 84 Toyota truck. Not because I HAD to, but because I thought I might as well since I stripped the threads for the spark plug in cylinder #1, and she had almost 375,000 miles on her. I found the reason for the stripped threads after I pulled the head. There was a very fine (almost invisible to the naked eye) crack running from the water jacket to the combustion chamber on cylinder #1, and the piston crown was as clean as a brand new piston out of the box. That particular cylinder had been leaking coolant for a LONG time, but not so much coolant you would immediately notice (or smell in the exhaust). I just topped off the radiator every six months or so. No other signs of coolant loss were evident, and there were no signs of any coolant contamination. It may very well be that the oil gallery which feeds the camshaft could be pissing oil into the coolant from a very fine crack that may not be visible unless you have the head pressure tested with dye or other methods.
Old 12-22-2005, 06:14 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
A good machine shop should be able to test all of these excellent ideas.
25 yrs with TOYOTA
Old 05-30-2006, 11:04 PM
Ford Boi's Avatar
Dealer : Tusket Toyota
- Other - '84 F-150 4x4. 351W
Last Online: 12-23-2006 07:31 PM
Ford Boi is on a distinguished road.
Ford Boi's Photo Albums
Question Re: Engine oil in coolant-22R
I have a 84 celica gt. with a 22re. with an insane oil to coolant and coolant to oil leak. but no smoke and cylinders dont have any cracks. i just replaced the head gasket and all the intake gaskets. drove it for about a day and a half and it was ok, ran 10 times better but there came the coolant and oil mixing in no time.. and the old gasket looked fine so. i also hear a noise on cold startup. who thinks its my timing cover ??
Old 05-31-2006, 12:19 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Default Re: Engine oil in coolant-22R
Sounds like a very good thing to check. A worn timing chain with broken guides will rub a hole thru the cover in no time at all.
Make sure the water pump also did not grind thru the timing cover.
25 yrs with TOYOTA
Old 06-01-2006, 12:21 AM
azredliner's Avatar
Dealer : Alexander Toyota
1995 Toyota Truck
Last Online: 10-31-2009 11:28 AM
azredliner is on a distinguished road.
azredliner's Photo Albums
Check your timing chain cover. There is a thin wall (about 1/4 inch) that seperates the timing chain from the cooling passage. When the timing chain gets slack from age, it will rub a hole in the cover and water will get into the oil.
An easy way to see if there is slack in the chain is to check the timing with a timing light. If the timing mark wavers, then the timing chain assembly is faulty.
Old 12-23-2006, 05:36 PM
Ford Boi's Avatar
me again with the same old problem. after replacing the head gasket, and then removing and closely inspecting the timing cover and all related parts and replacing with all new gaskets, i STILL have the oil and coolant mixing, although after the front end job it was alot slower leak. I have the head off again, and cant find any sign of cracks and there was no sign of a leak on the head gasket. the cylinder walls look fine, and so does the block. all i can suspect is hairline crack in the head to small to see. I'm going to rip the timing cover off again too, since its easily accessible and gaskets are cheap. im semi-fed-up with this motor and thinking of buying a used one. despite the fact that this one runs absolutely mint and nothing is even worn in it. if any of you have more ideas about what might be wrong, let me know. thanks.
OK get this. i just wrote this thing and decided to go back out in the shop and mess with the motor a bit more. i figured i'd take out the valves and look again form ANY sign of cracking on the head. as i was looking at it, i noticed one of the damn plugs uner the cam was QUITE loose, i actually gave it a couple turns with my fingers and it came out. and the threads were full of oil and so was the area inside the water jacket below. so I'm guessing this was my problem all along. how stupid is that? could it possibly get any stupider????? maybe this could add to the other ideas you guys had of internal coolant/oil leaking problems.... dont even ask why or how this stuff happens to me.
Old 02-27-2007, 07:27 PM
Dealer : Sunny King Toyota
1995 Toyota Truck
Last Online: 04-08-2007 10:50 AM
tnau664 is on a distinguished road.
tnau664's Photo Albums
Hey Graig. Did you ever find out how the oil was getting into your coolant? I'm suffering through the same issue of lost coolant. I'm loosing about a pint every 30 miles with no leaks. Sounds exactly like what you described here.
Thanks
Terry
Piedmont, Alabama
Old 09-30-2007, 11:02 AM
Dealer : Best Toyota
1997 Toyota Tacoma
Last Online: 09-30-2007 11:02 AM
CGriff is on a distinguished road.
CGriff's Photo Albums
Angry Re: Engine oil in coolant-22R
I don't know if people are still replying to this thread but I have a 97 Toyota tacoma, structuraly this machine is in very good shape but I checked the coolant today and noticed the resvoir was pretty well empty and at the bottom there was like dark oil looking fluid. From what I read on this thread this is very bad as it seems oil has entered my cooling system, to make matters worse I checked the tail pipe and there is dark liquid comming out there also . Does this mean I have a blown head gasket? or is this even worse than that.
Ty guys I eagerly await you response.
CGriff
Old 10-05-2007, 08:45 AM
Tennesseestorm's Avatar
Dealer : Phil Bachman Toyota
2000 Toyota Tundra SR5 4wd V8,
- Other - 1972 Caprice Estate
Last Online: 08-04-2009 08:26 PM
Tennesseestorm is on a distinguished road.
Tennesseestorm's Photo Albums
My grandpas 1990 Mazda 929 had oil in the coolant... it never overheated and it never had coolant in the oil. It was a blown headgasket. It was repaired, but still has oil in the coolant. Obviously not repaired properly.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/out-of-production-trucks-and-suvs/48222-engine-oil-in-coolant-22r/
Posted By For Type Date
Engine oil in coolant-22R - Tundra Solutions Forum This thread Refback 08-27-2009 03:23 AM
Engine oil in coolant-22R - Tundra Solutions Forum Timing chain wearing through This thread Refback 08-02-2009 07:45 AM
Anyone know how to 'unfreeze' an engine coolant plug? simon barsinister Engine & Drivetrain 4 08-22-2005 05:20 PM
Engine oil cooler and trans oil cooler installed keninsb Engine & Drivetrain 10 06-22-2005 03:50 PM
accidently drained my transmission oil then added more engine oil, what should i do? bLaM139 Engine & Drivetrain 13 02-12-2005 12:16 AM
Well, it's the oil..... akauth Engine & Drivetrain 9 06-12-2002 07:32 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
