Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 11-30-2005, 12:08 PM
otacg78's Avatar
Dealer : Beaver Toyota Of Santa Fe
1996 Toyota T100
Last Online: 02-11-2006 04:41 PM
otacg78 is on a distinguished road.
otacg78's Photo Albums
Default its whiney
HI!! my 97 t100 4x4 whines. It does it all the time so i dont think its the clutch. It is a high pitched whine that is most heard at a low idle, but when first (gear) is engaged it whines more pronounced. It whines a little through all the gears though and when im in 5th and let of the gas it whines a bit louder. any ideas?
Aint no kinda ugly that beer can fix.
Old 11-30-2005, 03:52 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Power steering pump? IDLE
A/C Idler pulley? IDLE
Alternator? IDLE
Waterpump? IDLE
Rear Diff? MOVING
Trans/Transfer MOVING or possible at IDLE
Fan pulley brace assy? IDLE
Does it whine at idle and not moving or only when moving?
Does it go away in 4th?
25 yrs with TOYOTA
Old 12-01-2005, 09:04 PM
otacg78's Avatar
1996 Toyota T100
It whines at idle and when it is moving, it is louder when it is in first gear, but it whines all the time. aT idle it is hard to hear and if you rev the engine up to about 1500 rpm's while idling it gets louder. when you start off in first and go to 3000 rpm it gets loudest. then tapers off as you go. so it does it at idle and moving.
thanks for the reply =)
