Originally Posted by vtwin_gary
hello all. i'm glad i found this place. it will take me a week to go through all the threads i wanna read.
i have a '93 t100
about 3 weeks ago i was driving down the road & it just died.
i pulled over & it started right back up, ran about 5 minutes & died again.
i towed it to my macanhnic while i was there it started right back up.
he siad his best guess was ignitor & it would be about 400 bucks to fix so drive it untill it quit again. well...
today was the day.
my question is this, how hard is this to replace? i'm not a total moron but i'm not a macanhic either. any help would be great.
thanks in advance
Have your mechanic pull a code and lets see if he is on the right track.
The igniter is on the drivers fenderwell under the hood. Its a small 3x2 silver looking box with a black wire connector sticking out of it. They have been known to fail =yes.
A code from the ECU would put you on a better track for a diagnosis, rather than just a guess.
Chilton/Mitchell manuals tell you how to access the ecu codes with a JUMPER WIRE.
Hope this helps
25 yrs with TOYOTA
