Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
LinkBack (13) Thread Tools Display Modes
  13 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 01-04-2006, 04:36 PM
Dealer : Toyota of Greenville
1995 Toyota Truck
Last Online: 04-27-2008 12:26 AM
MonsterMaxx is on a distinguished road.
MonsterMaxx's Photo Albums
Default BEWARE Eaton True Trac - bolts fall out
Just thought I'd drop you folks a little warning.
Here's photos of my Eaton Truetrac which the bolts fell out of in under 10,000 miles destroying my entire rear end - truetrac = garbage, new ring and pinion = garbage, new bearings = garbage, housing = garbage, axles = garbage. Replacement of the third member alone will be in excess of $1500, plus axles, bearings etc.
There are NO safety locking devices on the 8 truetrac bolts!
Eaton refused warranty on this item which was clearly a defect in their design process.
Truck has a stock motor and stock tires and is run 100% on the street.
Guess I won’t be running Eaton truegarbage in my Toyota again.
In a conversation with Reider they say that while this is not a common occurance, it does occur with some regularity since there is no retention system.
BEWARE Eaton True Trac - bolts fall out-truetrac1.jpg   BEWARE Eaton True Trac - bolts fall out-truetrac3.jpg   BEWARE Eaton True Trac - bolts fall out-truetrac2.jpg
Old 01-04-2006, 05:38 PM
MOREPOWER's Avatar
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
MOREPOWER's Photo Albums
Default Re: BEWARE Eaton True Trac - bolts fall out
never heard of an Eaton truetrac, only Detroit truetrac. whats the difference i know Detroit has helical gears.
Old 01-04-2006, 06:05 PM
wylcat's Avatar
DIRT BAG
Dealer : Sparks Toyota
2002 Toyota Tundra,
2000 Toyota 4Runner
Last Online: 11-15-2009 09:01 PM
wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence.
wylcat's Photo Albums
sorry to hear about the damage, but that should have been making a terrible noise before it got that bad.
HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
Old 01-04-2006, 11:23 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Arrow Detroit
EATON does not make the Tru-Trac, DETROIT makes it.
Old 01-05-2006, 01:27 AM
MOREPOWER's Avatar
thats what i figured so what differential is it.
Old 01-07-2006, 10:36 PM
1995 Toyota Truck
Nope, Eaton owns and makes the Truetrac. I too thought it was Detroit - it's not.
When I first heard it, yes it was a terrible squeeking.
I figured front wheelbearings. Pulled over and felt for temps. Couldn't find any hotspots, rolled it back and forth - no noise.
It was quite intermittnet and I was only 20 or so miles from home so I ran her on in.
Old 01-07-2006, 11:10 PM
MOREPOWER's Avatar
check out this thread http://www.pavementsucks.com/forums/...hp?topic=15138
the guy broke a Detroit true-track, found it while searching a manufacturer.
have yet to find Eaton as a builder for it.
Old 01-08-2006, 10:30 AM
H2O_MAN's Avatar
Arrow NOT an EATON product.
NOPE - It's not an EATON product or product made by EATON.
EATON did make for TRD and KAZUMA...
Did you get a box, part #, warranty card or installation instructions with the TrueTrac?
Who did you buy it from?
Who installed it?
Old 01-08-2006, 02:02 PM
MOREPOWER's Avatar
OK this is what i found, the Detroit true track built in 2002 had two helical gears and each end cap had four #8 grade bolts coarse threads, apparently they had problems with the cheap bolts backing out, every one had a problem with the bolts backing out. well not everyone had a problem.
they redesigned it and now theres three gears and six bolts fine thread holding the end plates together. no problems with this one.
trachtech inc makes the Detroit trutrac formerly known as Detroit Automotive Products until 1979.
I'm interested because i was shopping for this LSD unit now I'm not so sure, Eaton LSD may be better or more reliable.
Old 01-12-2006, 09:07 AM
1995 Toyota Truck
When I called Reider I said my Detroit TrueTrac has failed.
They said that it's not Detroit, it's eaton and gave me the tel#.
I called Eaton and they agreed it's their product, but denied any warranty.
Was it a sellout? I do not know, but them's the facts as best as I can tell you.
It is an Eaton product.
The bolts backed out.
This ended up destroying the entire third member.
Eaton Denied any warranty, even though they admit it's theirs and that there is some history of problems like this.
Take it as you will...
Old 01-12-2006, 06:44 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: 11-20-2009 07:27 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
Lawyer???
A company that sounds like PHabtech sold me some spindles which ended up breaking and bending ALOT and breaking alot. They said "To bad". I explained the design flaw which is because they put the axle below the lower A-Arm which in turn makes the lower A-Arm a pivot point pushing the upper A-Arm into the engine bay. This is exactly what happened. Well my wife works at a law firm and just had the boss write a "Nice" letter and I got my money back. Granted I had to pay for everything else but I got $400 back???
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 01-31-2007, 11:18 PM
4digchevy
Guest
Posts: n/a
4digchevy's Photo Albums
Exclamation Re: BEWARE Eaton True Trac - bolts fall out
I dont own a tundra, I have an 88 yota. I will probably never in my life post another thread, but I was google searching about truetrac and i came upon this forum. I couldn't stand you all arguing about something you clearly have no idea what you are talking about . For one, obviously none of you know that Detroit is actually owned by, a branch of, a division of, whatever you want to call it by Eaton. If you dont believe it. Ever been on www.eaton.com??? Go there, look up "differential". Second, I believe that your bolts fell out of your diff, but is it because the True Trac is poorly designed? highly doubted . Did the thought ever cross your mind that they were not torqued properly when installed??? Whoever installed it probably torqued the bolt to the Eaton spec not the Detroit spec. haha, oh ya they are the same friggn' thing. How about, don't argue about something unless you are 100% sure you know what you are talking about. You sound like a bunch of women. "Its made by Eaton", "no its made by Detroit," you are all right all along, so stop arguing. it is very annoying.
By the way, sorry to hear about your diff. No probs with mine for 40000 miles, but i also installed it. go figure.
Old 02-01-2007, 12:16 AM
MOREPOWER's Avatar
Way to be an arse a year later
Old 07-17-2007, 06:55 PM
- Other -
Last Online: 07-17-2007 06:57 PM
just2showu is on a distinguished road.
just2showu's Photo Albums
digging up bones again, but just want to get to the bottom of this...
Old 07-18-2007, 12:36 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Oh YA Eaton Detroit Truetrac Differentials - summitracing.com
Why does it say
Differential, Eaton Detroit Truetrac, 30-Spline, Toyota, 4Runner/ Pickup, Each
Now I am really confused. It says both
Here is EATONS website and it calls it a DETROIT
DETROIT TRUETRAC
I was thinking about one of these, as my TRD LSD just wont cut it anymore. It slips when I abuse it
I like the idea of the torsion gears
25 yrs with TOYOTA
LinkBack to this Thread: http://www.tundrasolutions.com/forums/out-of-production-trucks-and-suvs/55096-beware-eaton-true-trac-bolts-fall/
Posted By For Type Date
Eaton posi perf. or truetrac which is better - Page 2 - Impala SS Forum This thread Refback 10-16-2009 01:44 PM
Diff Locker Question - Page 2 - Tacoma World Forums This thread Refback 02-22-2009 02:17 PM
What size differential does the XR have?? - Page 4 - CustomTacos.com Forum This thread Refback 01-03-2009 04:36 PM
What size differential does the XR have?? - Page 3 - CustomTacos.com Forum This thread Refback 01-02-2009 09:26 PM
Detroit TrueTrac maintenance alert - Nissan Titan Forum: Club Titan Forums This thread Refback 12-19-2008 10:47 AM
1999 Mountaineer. Getting Stuck, Need Differential Mod. Getting Stuck. - Ford Explorer Ranger Enthusiasts Serious Explorations This thread Refback 05-18-2008 09:18 AM
Dodge Talk Community Forum - Need Advice/Opinions This thread Refback 05-16-2008 07:30 PM
Limited slip Auburn or Eaton Detroit| Dodge Truck World Topic This thread Refback 12-07-2007 07:29 AM
MKIII Tech :: View topic - *IJ's Build* This thread Refback 02-02-2007 11:01 PM
MKIII Tech :: View topic - *IJ's Build* This thread Refback 02-02-2007 12:03 PM
MKIII Tech :: View topic - *IJ's Build* This thread Refback 02-02-2007 11:28 AM
MKIII Tech :: View topic - *IJ's Build* This thread Refback 02-02-2007 10:54 AM
Kvasir This thread Refback 12-06-2006 04:29 PM
DIY: How To: Toytec Lift Install SMTRDSPORT Tacoma 62 09-18-2009 08:39 PM
We Got Jokes!!! -Thread 2- Possum Off-Topic 500 01-30-2005 07:56 PM
*The BS Thread* - READ ONLY - Possum Texas 1253 05-06-2004 04:14 AM
