Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 01-17-2006, 09:43 PM
Last Online: 04-28-2008 11:28 AM
jja141 may have some regrets.
jja141's Photo Albums
Default '95 pickup failing emissions test
Hello, I've got a '95 Toyota pickup DLX 4X4 with the 22RE engine that just failed the state emissions test because the NOx levels were high.
My limited knowledge of engines leads me to suspect that the cause could be either a bad oxygen sensor, faulty EGR system, or a clogged catalytic converter. Has anyone ever had this problem? The only thing I've noticed that may be related is that when I restart the engine after it's already at operating temperature, the idle is low and rough. But after I drive for a few minutes, the standing idle seems fine. It always idles fine when cold.
I also noticed that after the emissions test the computer screen read "vehicle underpowered." Not sure if that is related. Does anyone have any insight or a gut feeling as to why the NOx levels are high? Thank you in advance for any feedback.
Old 04-06-2006, 06:03 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 177
mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light.
Default Re: '95 pickup failing emissions test
I think you answered your own question.
An underpowered vehicle with hogh NOX,
First make sure EGR system is oprerating properly.High combustion temps can cause this.
The next thing would probably be replacement of the CAT Converter. If the converter has deteriorated and is partially plugged, this will definatly cause excessive NOX if its not reburning the exh in the RHoDIUM part of the cat.
Just a few thoughts
25 yrs with TOYOTA
RENTAL VEHICLES
To many people over do it with oil concerns marks tundra Engine & Drivetrain 148 02-03-2009 08:57 AM
Best oil to run in the 4.7 Tundra? SMOKEATR Engine & Drivetrain 69 03-22-2007 05:33 PM
We Got More Jokes!!! -Thread 3- Salty_Dog Off-Topic 500 06-12-2005 09:38 AM
