Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 01-21-2006, 04:23 PM
MIKEGOUGH1's Avatar
Dealer : Springhill Toyota Scion
2008 Toyota Tundra 5.7L SR5 Crew Max
Last Online: 10-21-2009 08:50 AM
Images: 2
MIKEGOUGH1 is on a distinguished road.
MIKEGOUGH1's Photo Albums
Default Check engine light on "97" T100
My son and I just finished changing the oil & filter, air filter and spark plugs on his new 1997 T100. While changing the plugs, one of the vacuum lines came undone. It caused it to run poorly until we located it, now all is well with the exception of the check engine light now being on. How do I reset the light?
Thanks
Mike
Old 01-21-2006, 05:50 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 11:27 AM
nhparrot's Photo Albums
Default Re: Check engine light on "97" T100
Thanks
Mike
It should reset itself after 3 trips with no dtc's reported or you can disconnect the battery.
~Glenn
Old 09-02-2006, 05:40 PM
Dealer : Lia Toyota Scion Of Colonie
2006 Toyota Tacoma
Last Online: 01-11-2007 01:07 PM
tigpoz is on a distinguished road.
tigpoz's Photo Albums
My '96 T-100 recently had the 'CheckEngine' light come on for the 1st time at ~120k miles. My experience might be interesting/helpful to others.
---- I stopped by the Toyota dealer and asked the guy at the service counter if they could check the code for me and see what the problem was. "Oh yes!" he said, "But you have to make an appointment and leave it with us. The code that your T-100's computer gives us will only point in the general area that we need to investigate to track down the problem. To diagnose the problem will be $65."
---- So I drove down the street to the auto parts store where the counter guy brought out the gizmo that reads the code and in 2 minutes had a print out for me for free that said "PO136 02 Sensor Bank 1 Sensor 2" which is the after-cat O2 sensor.
---- I went home and crawled under the truck and was disconnecting the plug-in for the O2 sensor when it occured to me that that booger had been down there under the truck in the open for 120k and maybe I should consider the possibility that, rather than a failed sensor, a corroded or dirty electrical connection had caused the problem.
---- So I cleaned up the connections, put it back together, disconnected the battery to clear the 'Check Engine' light, and sure enough, all was well. No 'check engine' light. Nice!
---- I think the experience at the dealers service dept. was especially interesting. I have to wonder--- If they would try to sell me that story about needing the $65 diagnosis, if I had bit would they then have tried to tell me I needed a new cat converter I didn't need? Or what?
Max
'96 T-100 4WD
'06 Tacoma 4WD
Old 09-07-2006, 01:54 PM
sak sak is offline
Dealer : Roseville Toyota Scion
1997 Toyota T100
Last Online: 10-16-2006 12:34 PM
sak is on a distinguished road.
sak's Photo Albums
Sorry to intrude on your dealership experience but I think I have to explain where the service writer's point of view.
First off, someone has to get paid to work. Unless you put the scan tool to pull the code, there is no real way of telling you whats wrong. So it is considered a diagnose time of $65. Thats a given. Go anywhere, even at independent grandma & granpa shops and they will sell a diagnoses fee up front before doing anything to it. Thats just how the business works.
Whatever they find, they should just sell you work for that. The only way to know if they are cheating you into paying for more is actually going through the process to see if they actaully will do it. Otherwise, there is no real way to know if that particular dealership practices falsifying information or not.
Anyhow, in your case as well as any DIY's case, luckily the local auto parts store offer's free code pulling via thier scan tool. This is because they want your business and hope and pray to god that you will buy the broken parts from them when you know what the code is.
Moreover, they assumption is that you will not know exactly how to fix it so you will end up buying part after part until you get it right. So in return, they will get your business (a lot of it) when its all said and done.
Just wanted to make some clarification so everyone knows how the system works.
Old 12-09-2006, 08:35 PM
1994 Toyota Truck t100,
1999 Toyota Sienna ce,
2006 Toyota Tundra dc sr5
Last Online: 11-18-2009 08:58 PM
loytotoy is on a distinguished road.
loytotoy's Photo Albums
As it happened to me the check engine light was fixed by replacing the 02 sensor on the exhaust. You probably want them to check the code because it aint cheap.
Resetting Check Engine Light garys2 Engine & Drivetrain 7 10-31-2006 05:43 PM
Check Engine Light? vegasgreed Engine & Drivetrain 22 07-31-2006 08:33 PM
63,000 miles & Check Engine Light tundra61 Engine & Drivetrain 3 11-17-2005 11:15 AM
Check engine light flashes about 5 Times... Amerikes 1Gen-Tundra 2 09-07-2005 08:48 PM
Check engine light; engine misses (newbie) skipster46 Engine & Drivetrain 2 02-08-2004 08:26 PM
