Originally Posted by zx636b
Does anyone know if centerforce or another aftermarket company makes a stronger clutch worth putting in an 88 4x4 22rec?
Becareful.... if you put anything stronger in than a CENTERFORCE STAGE 2
your probably going to knock the thrust bearings out of that engine. I have seen it more times than I can remember.
The centerforce stage 2 is a great clutch.
25 yrs with TOYOTA
