Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 03-20-2006, 09:32 AM
Dealer : Toyota Of Scranton
1997 Toyota T100
Last Online: 04-03-2006 11:40 AM
rjv140 is on a distinguished road.
rjv140's Photo Albums
Default 97 t100 top end noise
i have a 1997 toyota t100 with the 3.4 motor in it is it normal to have a small top end noise when the truck is first started once warmed up the truck seems to quiet up im not sure if it is the valves ticking or what?
Old 03-25-2006, 01:02 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: 97 t100 top end noise
A small bit of noise is normal, but when you say it "goes away" that opens up several options.
Exhaust leak?
Piston slap?
Aftermarket oil filter?
Valve adjust?
Any chance for you to record the noise and post?
The 1997 T-100 is a great truck as is the 3.4 a really nice engine.
25 yrs with TOYOTA
Old 03-25-2006, 01:54 PM
Dealer : Don Jacobs Toyota
2004 Toyota Tundra
Last Online: 09-22-2006 11:34 AM
Ballmj is on a distinguished road.
Ballmj's Photo Albums
Hello,
I've got the same year truck and engine. I also had a noise that almost sounded like a loose heat shield but would go away after a few minutes. I had a hard time where the sound was coming from. It turned out to be a cracked flex plate in the tranny. If not taken care of it can cause much more damage. My truck has 145,000 miles on it. I hope this helps.
Old 03-27-2006, 04:09 PM
1997 Toyota T100
there is a slice in the muffler is that what u mean as far as an exhaust leak and the truck is a stick im not sure if urs is a auto or what
Old 03-27-2006, 06:15 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
I was thinking an exhaust manifold tick.
A flex plate broken is for a AUTOMATIC, That is a very good suggestion.
Do you hear the noise under the hood or inside while driving?
Maybe time for a valve adjust?
Do it get worse IN DRIVE w A/C on?
25 yrs with TOYOTA
Old 03-30-2006, 10:07 PM
bigbadktm's Avatar
1998 Toyota T100
Last Online: 02-08-2009 03:19 PM
bigbadktm is on a distinguished road.
bigbadktm's Photo Albums
Originally Posted by Ballmj
Hello,
how did you find out. i have that loose rattley heat shield sound right now. taking off it rattles, certain rpms it rattles. any other tell tale signs, or how much to diagnose? mine is a 98 with just over 150k
Old 03-30-2006, 10:12 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
The exhaust crossover pipe (behind the cyl heads) has a heat shield welded to it. They used to crack the welds and rattle at times too.
25 yrs with TOYOTA
Old 12-14-2006, 02:32 PM
Dealer : Spitzer Toyota
1997 Toyota T100
Last Online: 01-11-2007 10:08 PM
fshnOBX is on a distinguished road.
fshnOBX's Photo Albums
I have a 97 T100 SR5 4WD 3.4 with the same noise. I think I narrowed it down to the cross over pipe. I was in an accident approx 2 years ago and the noise reared its annoying head about 6 months later. I have cut away some of the heat shield and it seemed to have gone away for awhile, but it has come back. I plan on taking the pipe off for better examination. BTW Nice '02
Old 12-15-2006, 11:12 PM
Tennesseestorm's Avatar
Dealer : Phil Bachman Toyota
2000 Toyota Tundra SR5 4wd V8,
- Other - 1972 Caprice Estate
Last Online: 08-04-2009 08:26 PM
Tennesseestorm is on a distinguished road.
Tennesseestorm's Photo Albums
The 96' T100 I was considering had the exact same rattle.... like a loose heat shield or something. Probably the same issue.
Valve "clicking" noise 2003 V8 BobJ Engine & Drivetrain 9 11-06-2009 07:27 AM
The front end noise is back again. tbrown78 Tacoma 10 11-25-2005 08:14 AM
Rear End Noise hpeeler 1Gen-Tundra 1 08-19-2005 01:43 PM
Weird Screeching Noise GaryFisher Engine & Drivetrain 5 02-16-2004 10:50 AM
Grinding exhaust noise? mr_tundra Engine & Drivetrain 5 10-28-2003 07:07 AM
