Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 06-22-2006, 04:41 PM
Dealer : Toyota Scion Central
Last Online: 06-30-2006 04:45 PM
ksoth is on a distinguished road.
ksoth's Photo Albums
Default '93 pickup electrical problem
I have a '93 Toyota Pickup with an electrical issue. The switch to turn on the headlights doesn't work correctly. The switch turns on the headlights just fine, but does not turn on the rear running lights or the dash lights, and the standard "key out of the ignition with headlights left on" noise does not come on. The bulbs are fine. When I tested the rear with a voltmeter, no voltage is getting to bulb when the lights are on. A relay that turns on when the switch is applied is working fine (I could only find one relay). So, something is messed up. Anyone know what other things I could look for? Thanks.
Old 06-22-2006, 07:37 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: '93 pickup electrical problem
Try these pdfs, they are the wire diagrams for the head and tailights
The tailight/dashlights have their own fuse and relay.
I would also suspect if equipped , the trailer wire converter box.
25 yrs with TOYOTA
Old 12-11-2006, 09:41 PM
1996 Toyota T100
Last Online: 03-16-2008 10:41 AM
eppoh is on a distinguished road.
eppoh's Photo Albums
I am having a similar problem but with the front parking lights and the lights on chime. I suspect the integration relay.
Will try one next time I am by the dealer. One little relay should not cost too much.
I'll let you know when I have tried it.
Old 12-16-2006, 12:40 AM
Tennesseestorm's Avatar
Dealer : Phil Bachman Toyota
2000 Toyota Tundra SR5 4wd V8,
- Other - 1972 Caprice Estate
Last Online: 08-04-2009 08:26 PM
Tennesseestorm is on a distinguished road.
Tennesseestorm's Photo Albums
Yes, sounds like relay issues. Typically, Toyota electrical systems are flawless. When something usually crops up, it is normally a relay, or where someone has tampered with the original electrical system for add-ons, etc.
Old 12-16-2006, 12:43 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
You got that right , you should see some of the stuff people do.
25 yrs with TOYOTA
Old 01-08-2007, 06:12 PM
Dealer : Sunrise Toyota Scion
1994 Toyota Truck
Last Online: 01-16-2007 05:55 PM
timebandit is on a distinguished road.
timebandit's Photo Albums
There are two relay's. The one inside on the fuse box is for the parking lights.
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
2000 Tundra Electrical Problem Steve Young 1Gen-Tundra 2 05-22-2006 03:55 PM
We Got More Jokes!!! -Thread 3- Salty_Dog Off-Topic 500 06-12-2005 10:38 AM
old Toyota 4WD pickup problem - transfer case shifter wallaceb Engine & Drivetrain 5 01-30-2005 07:21 PM
Wiring problem for ARE Tonneau Cover...HELP!! surfwagon56 Truck Bed Tonneau Covers 0 02-01-2004 12:28 PM
