Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 06-28-2006, 10:15 AM
Sunhouse's Avatar
2004 Toyota Tundra
Last Online: Yesterday 07:08 PM
Sunhouse is on a distinguished road.
Sunhouse's Photo Albums
Default 89 front oil seal
My reliable 89 has an oil leak from the oil pump area. It is coming from behind a plastic cover over the oil pump.
I can not see behind this cover and was wondering if anyone has experience with the oil pump seal.
The repair manual says i have to remove the front diff and oil pan to remove the oil pickup so i can remove the oil pump and replace the seal
I have been told that i don't have to remove the pump to replace the seal just get to the front of the oil pump and press in another seal
any insight to this oil seal would be great
engine 6 cyl 4wd 5 speed extracab 1989
Thanks
Dave
2004 Tundra Limited Access 4x4 Salsa Red Pearl Matching A.R.E. LS ll Lid, Fog Light Mod
1989 Pickup Deluxe Extracab 4x4 Blue 196000 City Miles and counting
Old 07-02-2006, 09:32 PM
Dealer : Toyota Of Portland
2000 Toyota Tacoma
Last Online: 10-09-2009 10:40 AM
theyotaguy is on a distinguished road.
theyotaguy's Photo Albums
Default Re: 89 front oil seal
An '89 with a 3.0 V-6,oil coming from behind the timing cover at the bottom-Right? You will have to remove the front covers,the lower pulley,and the timing belt,but you do not have to remove the pump to change the front crank seal.It just pops out,and tap a new one in.Depending on the last time you changed the timing belt,accessory belts,and water pump,now would be the most convenient time and then you can forget about all that stuff for another 60000 miles.
*A parts man with a code-reader is NOT your friend!
*The most expensive parts are the cheap ones that let you down.
*Testing ROCKS - parts swapping is for the .
*Anybody can take a dump in a box and mark it guarranteed,but what you really need to do is buy a quality part.... "Tommy Boy"
Old 07-05-2006, 01:33 PM
Sunhouse's Avatar
2004 Toyota Tundra
theyotaguy
The bottom is correct. Thanks for the info
Dave
Dave
4.0L V6 -- Oil Change Horror Story kymatt Engine & Drivetrain 15 02-19-2005 12:20 PM
Front differential oil level filhiol Engine & Drivetrain 3 03-23-2004 10:35 PM
Noise in front after Differential Oil Change staggarlee Engine & Drivetrain 18 10-02-2003 02:32 PM
What Oil are you using? Son of Odin Engine & Drivetrain 37 09-11-2003 08:36 PM
OIL oil OIl, sigh, growl, vomit jeremy2525 Engine & Drivetrain 1 08-14-2003 01:39 PM
