Drain trans.
Remove rear trans mount and bracket
Move trans back approx 3" and then twist it counter clockwise so the shift tower is now facing toward the drivers side of the vehicle.
slide trans back farther, lower bellhousing down past flywheeel and slide transmission out FWD to replace clutch.
Should be able to do this clutch in 30 minutes or less.
Good Luck
25 yrs with TOYOTA
