Re: Check engine light
The switch signal is the Idle Position Switch.The only way that code 51 will be set is when you have the terminals TE1 and E1 shorted together (while checking codes) and either: A) the idle switch contacts are not closed and/or B) the shifter is in any position other than P or N (on automatic trans vehicles). Fix the Oxygen Sensor first,and then check the IDL contacts.The easiest way to do this is to jumper the check connector while it is idling and see if the RPM drops and the ignition timing returns to the base timing setting of 10 deg BTDC.If it does,clear the codes and forget it,you may have bumped the throttle or accel pedal while testing.If it doesn't,you may need to check the throttle cable for proper slack when released,clean the throttle body,or adjust the Throttle Position Sensor.
*A parts man with a code-reader is NOT your friend !
*The most expensive parts are the cheap ones that let you down.
*Testing ROCKS - parts swapping is for the  .
*Anybody can take a dump in a box and mark it guarranteed,but what you really need to do is buy a quality part.... "Tommy Boy"
