Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 12-28-2006, 10:52 PM
1996 Toyota T100
Last Online: 03-16-2008 10:41 AM
eppoh is on a distinguished road.
eppoh's Photo Albums
Default T100 ignition wires
My T100 with about 79000 miles is getting a little harder to start. Not bad, but it turns probably 5 or 6 revolutions before it starts. I does idle a little rough.
It had a major service at 60,000 which included injection service.
Looking at the ignition set up, I occurs to me that those plug wires would wear out twice as fast on this engine as those on a V6 with six plug wires. On this one it look like the plugs must fire twice each revolution. That would be the equivalent of about 160,000 miles on the wires.
Any other ideas?
Old 01-07-2007, 02:07 PM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX,
2009 Toyota Camry HV (wife's car)
Last Online: 10-04-2009 05:29 PM
THarms is on a distinguished road.
THarms's Photo Albums
Default Re: T100 ignition wires
Any other ideas?
Assuming that you are still running the oem spark plugs, it may be time for them to be re-gapped or a complete new set. This is based on my experience that the oem plugs tended to wear out extremely quickly until I upgraded to double platinum plugs. As the gap widens, the truck definitely gets harder to start.. but once started it usually ran ok until the plugs got really bad.
2009 Camry Hybrid (wife's car)
2001 Sequoia Limited (family SUV)
1999 Solara SLE (kid's car)
1995 T100 4x4 (my toy)
Old 01-21-2007, 05:57 PM
Dealer : Longo Toyota
2004 Toyota Camry SE V6,
2007 Toyota Tundra DBL Cab Limited 4X2,
1995 Toyota Camry
Last Online: 03-14-2009 10:45 PM
Robin25113 is on a distinguished road.
Robin25113's Photo Albums
I have 92K miles on my V-6 T100 4X4. I switched to Iridium NGK's. Idles sweet and picked up 1 MPG. If you use them, use anti-seize compound as they will be in for 100K miles. Don't forget the silicone on the spark plug boots. Got mine for $6 on E-bay. Hope this helps.
Old 07-31-2007, 02:44 PM
Dealer : Toyota of Santa Barbara
1997 Toyota T100
Last Online: 07-01-2009 05:44 PM
Surf WRaX is on a distinguished road.
Surf WRaX's Photo Albums
Hello, Are you saying that the NGK Irdium plugs that are single ground work well in your T100 v6? Are they still in there? I bought some Denso Iridium single ground plugs because sparkplugs.com said they work as did many threads on here, but the explanation about the DIS ignition makes me thing I need to get some dual ground plugs instead.
1995 T100
Old 10-07-2007, 03:41 PM
1994 Toyota Truck t100,
1999 Toyota Sienna ce,
2006 Toyota Tundra dc sr5
Last Online: 11-18-2009 08:58 PM
loytotoy is on a distinguished road.
loytotoy's Photo Albums
Okay you've mentioned plugs and wires so look at your rotor button, your distributor cap, make sure the engine is grounded well and cables are not corroded. Extreme hot weather is hard on batteries, too. These things don't fix themselves. I would suggest that you stay stock with all components.
1995 T100 Video... Ric17 Out-of-Production Trucks & SUVs 3 01-10-2007 12:14 AM
GMC Sierra vs Toyota T100 Video... Ric17 Out-of-Production Trucks & SUVs 2 12-22-2006 12:00 PM
Did anyone here own a T100 before the Tundra? If so, did you like it? Tennesseestorm 1Gen-Tundra 2 10-02-2006 03:50 AM
1995 Camry – AM2 fuse blows when turning ignition – Solution austinwpt Camry 0 08-29-2006 07:28 PM
Sequoia Alarm Install Help nhparrot Electrical & Computer Systems 1 03-27-2005 06:50 AM
