Just checked out my gasket and it was completely rotted away. I had some leftover soft foam pipe insulation so I used about 2" of that. Since it's already split in half and has the self stick adhesive, I just wrapped it around the steering shaft and stuck it together. Fits perfectly and no noise! Not bad fer less than $5 solution. I only unbolted the old gasket to completely clean up the gasket so it would be smooth and no extra rotted pieces to deal with. Other than that, I only used some scissors to cut the pipe foam with to do this!
