Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 01-10-2007, 10:05 PM
Dealer : Landers Toyota Scion North
1996 Toyota T100
Last Online: 01-11-2007 10:37 AM
96T100SR5 is on a distinguished road.
96T100SR5's Photo Albums
Default 96 T100 door lock problem
After 110K miles my 96 T100 decided to give me a problem - the driver side door lock has developed an issue. When I press the keyless entry - it just kinda wiggles the doorlock - like its giving a half hearted attempt. I press it two or three times before it manages to wiggle enough to unlock the door. And the problem seems to be worse on cold days. Anyone else ever hear of this?
Old 01-21-2007, 06:01 PM
Dealer : Longo Toyota
2004 Toyota Camry SE V6,
2007 Toyota Tundra DBL Cab Limited 4X2,
1995 Toyota Camry
Last Online: 03-14-2009 10:45 PM
Robin25113 is on a distinguished road.
Robin25113's Photo Albums
Default Re: 96 T100 door lock problem
Probably time for a little lube on the mechanisms. It fixed mine.
Old 01-22-2007, 12:44 PM
jomentum's Avatar
Dealer : Ron Carter Toyota
1997 Toyota T100,
2007 Toyota 4Runner,
2004 Toyota Corolla,
1996 Toyota RAV4,
2008 Scion xD,
1995 Toyota 4Runner
Last Online: 10-29-2009 09:32 PM
jomentum is on a distinguished road.
jomentum's Photo Albums
mine did that untill the power lock actuator finally died..
Old 03-07-2007, 09:01 PM
tacomatrdsport2591's Avatar
Dealer : Fairfield Toyota
- Other - '87 Corolla FX16 GTS
Last Online: 06-05-2008 09:30 AM
tacomatrdsport2591 is on a distinguished road.
tacomatrdsport2591's Photo Albums
I agree with the first reply...you probably need some good lube and you'll be good to go. I can connect with this issue, as the power locks on my 87 rolla seem to freeze up pretty good when it gets cold. Sometimes I have to press the button or unlock it with the key several times for the locks to come all the way undone. Likely it's just the lubricants gelling up in the cold. And as for the second reply, his locks probably remained unlubed or poorly lubed for so long it put too much stress on the mechanism and caused it to fail. Have a look around and see to lubing them up good, and let us know how it turns out!
"Close your mouth before you chew."--Marie Barone....."Close your mouth before you talk!"--Frank Barone
T100 History H2O_MAN Out-of-Production Trucks & SUVs 15 10-20-2009 10:25 PM
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
T100 Drag link/Steering relay rod safety related failure *PICS* H2O_MAN Engine & Drivetrain 15 01-18-2008 06:04 PM
IS the Toyota Tundra brake problem very common? FIN433 Brakes 38 02-27-2007 07:50 PM
Can my T100 do this? sallemann Out-of-Production Trucks & SUVs 2 02-12-2006 05:54 PM
