Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 04-03-2007, 07:50 PM
Dealer : Sunny King Toyota
1995 Toyota Truck
Last Online: 04-08-2007 10:50 AM
tnau664 is on a distinguished road.
tnau664's Photo Albums
Default Chasing Coolant Lose
Hi guys. I've been chasing a coolant lose in a '86 Re for a couple of months now. My brilliant mechanic, no offense intended, said: "Hey your radiator is leaking." He didn't even check the petcock!
Bottom line, I've decided to do it myself. Here's the question??? My Peterson's book says you need to remove the oil pan before removing the timing chain cover. Can anyone tell me if this is really necessary? I thought, hey, while the head is off, I'll replace the cover, chain, and tensioner and save work later.
Thanks for looking
Terry
Old 04-06-2007, 03:50 PM
jayotto4's Avatar
Dealer : Toyota of Newport
2005 Toyota Tacoma,
- Other - 1988 pick up
Last Online: 08-13-2009 12:30 PM
jayotto4 is on a distinguished road.
jayotto4's Photo Albums
Default Re: Chasing Coolant Lose
I do not believe you have to. If you take the head off bring it to some one to ckeck for cracks. I had a 22 re that had over heated and it would loose fluid over a few weeks before it over heated again. It ended up being a small crack in the head causing the fluid to be burnt off over time without being noticed. Other culprite that I know of is that the chain guides wear out and the chain chews through and coolant leaks out. Check the hoses and the radiator because they do tend to go. I replaced mine a couple of times.
http://community.webshots.com/user/jays99taco
"power corrupts, and absolute power corrupts absolutely" Lord Acton (1834-1902)
Old 04-07-2007, 09:57 PM
1995 Toyota Truck
Thanks for the reply Jay. I got the head off today, and the chain and cover look OK, so that work gets skipped. I had 2 headbolts that were rusty red, 1 that was black with exhaust and the others were oily. That seemed all over the place for me. I'm cleaning it up and putting the new gasket on. This is not my only ride, but I enjoy driving the Toyota.
Terry
Old 05-01-2007, 01:29 AM
Dealer : Longo Toyota
2004 Toyota Camry SE V6,
2007 Toyota Tundra DBL Cab Limited 4X2,
1995 Toyota Camry
Last Online: 03-14-2009 10:45 PM
Robin25113 is on a distinguished road.
Robin25113's Photo Albums
Now is the best time to do the Timing Chain. Your half way there. It will run better after.
05 Tacoma - Slight Coolant Loss from Reservoir Tank SuperBusa Tacoma 13 07-10-2007 10:44 PM
Lose of Coolant tnau664 Out-of-Production Trucks & SUVs 2 02-06-2007 06:35 PM
Coolant loss 2005 Camry I4 winstead1 Camry 0 01-27-2007 11:46 AM
Low Coolant in Reserve Tank...have couple ?'s PagalDesi4Life Engine & Drivetrain 6 01-07-2007 08:52 PM
Anyone know how to 'unfreeze' an engine coolant plug? simon barsinister Engine & Drivetrain 4 08-22-2005 05:20 PM
