Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 05-02-2007, 06:18 PM
Dealer : Capitol Toyota Scion
- Other -
Last Online: 05-02-2007 08:04 PM
flogzilla is on a distinguished road.
flogzilla's Photo Albums
Default 1986 Turbo Puzzle
Hi, I just found this site and hope you guys can help me out here. My '86 Toyota PU has a 22RTE engine and I just had the head gasket and timing chain replaced at 230,000 miles. While I was at it, I replaced the cat converter and muffler and most of the pipe. Within 100 miles of this service, the turbo has stopped giving me boost. We tested the impeller and it builds to the correct pressure and seems to work fine. When I drive, though, I can't hear the usual whine and there is no burst of acceleration to press me into the back of my seat. But the boost light comes on and everything "acts" normal. Is there some sensor or diverter or switch that I am unaware of? I am hoping there is a guru among you that will educate me in this fine work of art. Thanks.
Old 07-20-2007, 05:03 PM
Dealer : Earnhardt Toyota
2005 Toyota Tacoma
Last Online: 07-20-2009 06:38 PM
qk94dawg is on a distinguished road.
qk94dawg's Photo Albums
Default Re: 1986 Turbo Puzzle
look for a boost leak or wastegate problem (not sure if these use gates or not)
Old 07-21-2007, 12:28 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Yes, it has a waste gate.
Why did you do the headgasket? Leaking coolant ? Overheated?
Was the head surfaced? rebuilt?
was it ok at first and got worse in 100 miles? or
was it not so good after all the work was performed ?
I have seen non Toyota timing chains cause retarded timing even tho all the marks were correct. They have the dots on the gears in the wrong spot.
Is the distruibutor in correctly?
Timing set properly with TE1 and E1 jumped
TPS functioning properly, if the idle contacs are stuck, it will think your idleing even tho your accelerating and not advance timing and may even cut fuel.
Over size exhaust will reduce back pressure and the turbo will have nothing to push against.(if ist to big)more than 1/8" over stock is too big.
High flow cats may cause this too, or plugged cats (even tho they are new) something might have happened to them, if the timing was off or something else is wrong.
Sorry so many questions
25 yrs with TOYOTA
Old 08-06-2007, 06:45 AM
2005 Scion xB,
2005 Toyota Corolla,
- Other - 84 Reg cab Long bed,
2007 Toyota Tacoma
Last Online: 10-25-2007 10:05 PM
hotbox05 is on a distinguished road.
hotbox05's Photo Albums
only problem with said statements above is there's really never too large of piping for a turbo.
within reason. for a stock 22rte i'd say 2.75 is max , built is like 3.0 inch
www.myspace.com/hotbox05
www.myspace.com/mertechperformance
Lookin' for 22r hop up parts
merTECHPerformance
Suzuki . FOX racing . Toyota . SCION .
www.CafexD.com
Old 12-20-2007, 04:18 AM
Dealer : Toyota Scion of Garden Grove
Last Online: 06-29-2009 04:52 PM
dough boi is on a distinguished road.
dough boi's Photo Albums
Turbo's need next to nothing for an exhaust. The bigger the better for turbo's. Ideally you'd want the biggest and least restrictive exhaust (or even no exhaust) on a turbo engine. Without any kind of restriction in the exhaust your turbo would definately spool much faster, and make it overall more efficient.
TOP MOUNTED Single Turbo Bolt on Kit!!!! Hollywood03 Engine & Drivetrain 69 10-10-2009 07:00 PM
Toyota SR-5 1986 Turbo vancchris Out-of-Production Cars & Vans 4 08-11-2007 05:13 AM
Breathing Exercises Salty_Dog Polls 33 01-16-2007 02:51 AM
Turbo or Supercharger for 2004 DC? bgsutton 1Gen-Tundra 12 09-01-2006 05:38 PM
Air Power Systems: Intercooled Turbo System keiphers Polls 30 03-31-2004 05:47 PM
