Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > Out-of-Production Trucks & SUVs
Old 05-06-2007, 02:48 AM
Dealer : Denny Hecker's Toyota
1993 Toyota Truck
Last Online: 05-10-2007 04:02 PM
yotamanmn is on a distinguished road.
yotamanmn's Photo Albums
Default Need help with 22RE
I have a 93 pickup with 22re. when the motor is cold, It idles rough, and rich and when the motor is warm, it does not idle at all and runs way to rich. The SE light is not on, and no codes come up. Need some help. Thank you
Old 06-07-2007, 11:47 PM
turningwrenches's Avatar
Dealer : Quality Toyota
1998 Toyota T100
Last Online: 05-02-2009 08:38 PM
turningwrenches is on a distinguished road.
turningwrenches's Photo Albums
Default Re: Need help with 22RE
coolant temp sensor for efi I ve replaced alot of them with that problem see if unplugging it helps the runnability of the vehicle , this will set the ses light on though. To clear it remove efi fuse
Old 06-08-2007, 12:06 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
The coolant temp sensor check is a great idea.
Also check the door in the airflow meter, the spring that keeps the door closed is know for going "BOING" and breaking. This will allow the door to open more than it should and flop around, causing the engine to run rough and rich.
25 yrs with TOYOTA
4x4 with 22r or 22re? anyone? tundrastorm Out-of-Production Trucks & SUVs 4 04-06-2007 03:58 PM
Swapping 22r block with 22re mcs Engine & Drivetrain 4 03-30-2007 09:28 AM
1989 22re heater woes stoutmouth Out-of-Production Trucks & SUVs 2 11-16-2006 04:32 PM
22re trc19 Engine & Drivetrain 1 08-13-2005 09:25 PM
Engine Ping 22RE Engine ratherbegolfing Engine & Drivetrain 1 02-07-2005 10:07 PM
