Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Performance Exhaust Systems
Performance Exhaust Systems Detailed discussions regarding performance headers, single, dual, street and off-hard racing exhaust systems for your vehicle.
This is a discussion thread titled "Custom exhaust modification, this ok?", within the Performance Exhaust Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 11-26-2007, 12:39 AM
Dealer : Texas Toyota of Grapevine
2002 Toyota Tundra
02TRDAC's Photo Albums
Last Online: 05-28-2008 06:55 PM
02TRDAC is on a distinguished road.
Default Custom exhaust modification, this ok?
This is what me and my two step bros all did to our Tundras...
Go to the passenger side rear door, look under there where your exhaust is and you will see about a foot of pipe off your cat(going to the rear of the truck) there will be an o-ring clamp....remove the o-ring clamp....now the muffler and the few feet of pipe on both sides of it are just hanging from rubber grommets, there are 2 or 3 of them....there are a bitch to remove, but leave them on the exhaust...not on the truck so you don't lose them....now that that exhaust is off....put that o-ring clamp on the pipe where it was on the removed piece of muffler pipe, tight enough to hold it on there loosly.
So you just removed your exhaust, and did it in a way that it is simple to reinstall with no extra work to get it back on....if you ever decide to.
If you leave the pipe on the truck like it is, it will be too loud and on the highway alsmot deafen you.
I forget the diameter of the pipe, you can measure yours, go to NAPA, Shucks....whatever you ahve and buy a 2' exhaust pipe in the same diameter and also get a 45 degree turndown(almost a foot long) that is the same diameter. Also buy one of those things that supports an exhaust pipe....it goes around the pipe and the other end you'll screw into your truck to hold it so it wont put stress on your headers from bouncing all over. Also get 2 U-bolt clamps....1 part is a U shape and the other goes ontop and screws onto the U, slightly larger diameter than the pipe, so it will fit around the pipe kinda loosely.Those 5 things should all be next to each other in the store.
Take the 2' pipe and the 45 degree turndown to any local muffler shop and ask if the can "swedge" both ends of the pipe for you, so that the 45 degree turndown fits in both ends of the pipe. Just deep enough so that the turndown fits inside the pipe a few inches....not too deep.Do NOT swedge the turn down, that is what you brought to "test fit" to see if it fits inside the swedged pipe.
The rest is easy.....the swedged pipe fits on the pipe where you removed the exhaust. The U-bolt clamp goes on the pipe to hold the existing pipe and new pipe together. The turndown goes inside the end of the swedged pipe....I think angling it halfway between the side and the ground sounds the best. Throw the other U-clamp on there to hold those 2 pipes together. Now put the support thing around the swedged pipe, in about the middle of the pipe, and have it pointed up towards the bed of your truck and find a place to use an existing hole with a bolt and nut, held tight enough to support the weight and you're done.
I don't know if you need to disconnect and then reconnect the battery so your computer redoes itself or whatever....but someone told me I should do that so I did.
Now it's louder, but not too loud....and sounds alot better.
My step bro explained it to me....now that the K&N Cold Air Intake allows your truck to breathe better, removing the exhaust....or getting different exhaust.....allows the truck to push that air out faster....which is good(according to him).
__________________________________________________ _____________
Just wanted to see if that sounds ok to you guys. I'm a computer guy, not a gear head :P
For $12 it sure sounds better and with the K&N and the exhaust I can tell a difference.
2002 Tundra V8 2wd. TRD, SR5, Chrome Packages. Metallic Silver Sky
http://laidbackguild.com/tundra/tundra.jpg
TIRES: Nitto Terra Grappler 285/70/17(33's)
WHEELS: 17"x 9" Moto Metal 951 Black Aluminum
SUSPENSION: Front Cornfed 2.5" spacers
STEREO: Kenwood 617DVD, fully motorized 7" touchscreen DVD player. Kenwood 6 3/4" 3way Door Speakers. Kicker Solobaric L7 12" DVC 750W 4ohm sub(wired @ 2ohms), in a custom 3.25 cubic feet, carpeted, ported 3/4" MDF box. Powered by a Kenwood 9152 900W RMS 2ohm Class D mono amp, with Rockford Fosgate 1farad Digital Cap. Playstation2 with 2 controllers. 400w power inverter.
INTERIOR: Tinted front windows 20%. Replaced all interior lights with blue LED lights. 9x Blue LEDs in each roof light, 6x Blue LEDs in each door light. Removed rear seat armrest for sub to fire into.
EXTERIOR: Black fender flares. Front and rear chrome bumpers. Chrome, turn signal, power rear view mirrors. Chrome step bars. Chrome bed rails. Plastic bed protector. Rear brake drums painted black.
PERFORMANCE: K&N FIPK2 Cold Air Intake. Custom exhaust...removed muffler, added 1foot of pipe, 45degree turn down.
PROTECTION: Always garaged. All components hidden/bolted down and face plate removed. Alarm system with glass break sensor mic. Springfield Armory XD SC .40 and me :-)
FUTURE MODS: Black Headlights w/matching clear corners. Tail lights. Mesh grill w/bumper insert. Additional rear window tinting. 2way Alarm system. Automatic 1push passenger window.
Old 11-26-2007, 12:40 AM
2002 Toyota Tundra
Default Re: Custom exhaust modification, this ok?
by the way.....I've put about 6,000miles on it since this mod and they have all gone about the same also, with no problems.
Old 11-26-2007, 02:17 PM
CHINKinatundra's Avatar
Dealer : Red McCombs Toyota
2002 Toyota Tundra
CHINKinatundra's Photo Albums
Last Online: 07-10-2008 08:22 PM
CHINKinatundra is on a distinguished road.
Send a message via MSN to CHINKinatundra
so are you basically bypassing the muffler? if so, why not just install an exhaust cutout?
Old 11-26-2007, 02:32 PM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Today 01:40 AM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
your probably loosing a ton of low end power without the muffler and with the k&n, in fact, i know you are because i had this setup for about a month and it was the worst thing ever.
2002 Tundra-SAS-Dana 50-Sterling 10.5-Inchworm 2.28 Dual Transfer Case-4.56 Gears-38.5 Thornbirds-ASP Underdrive Pulley-Flowmaster Muffler
Build Thread-
SAS on 02 Tundra
Old 11-26-2007, 05:36 PM
Dealer : Kern Toyota
2003 Toyota Tundra 4.7 with duals
Jetes03tundra's Photo Albums
Last Online: Yesterday 11:30 PM
Jetes03tundra is on a distinguished road.
Send a message via AIM to Jetes03tundra
just cutoff the muffler and put a glasspack in there instead!!
2006 Chevy Silverado 4wd 5.3 4.10 gears
- Dual flowmaster 40's out back exiting at the sides
- Blackbear 87 octane tune (good for 25hp and its amazing, no more torque management)
- LT headers
14.41 @98mph
A REAL truck.
Old 11-26-2007, 07:17 PM
Dealer : Doxon Toyota
2002 Toyota Tundra mica green trd
sr5mike's Photo Albums
Last Online: Today 03:08 AM
sr5mike is on a distinguished road.
With no muffler your torque just went in the toilet.
Old 11-26-2007, 08:14 PM
2002 Toyota Tundra
Doesn't seem like it.
Old 11-26-2007, 08:44 PM
apimpdad's Avatar
2002 Toyota Tundra
when i had this on my truck, the low end grunt just wasnt there. i immediately noticed difference when i did this mod. since then i re-installed the stock air box and put my flowmaster muffler back on and now i have the low end that went missing. not to mention, the mpg improved also.
Build Thread-
SAS on 02 Tundra
Old 11-26-2007, 09:18 PM
2002 Toyota Tundra
It would be interesting to see Dyno results or 1/4 times or something to compare the 2 because it seems the same if not better to me.
Old 11-26-2007, 10:06 PM
Ltning/QC10nomas's Avatar
Dealer : Toyota Scion of Orlando
Ltning/QC10nomas's Photo Albums
Last Online: 09-17-2008 12:32 PM
Ltning/QC10nomas is on a distinguished road.
You may or may not be loosing low end.
Who cares you were happy enough with your mod to want to share it with us so don't worry about it and congratulations on fixing the sound to your liking cause these are not race trucks or sled pullers anyway so why would anyone waste money on a dyno for a 240 or less horse 5000lb truck.
Make it look and sound like you want and enjoy it
If you don't tell or write lies you have much less to remember and it only takes one to have ZERO credibility M.F..
Old 11-26-2007, 10:09 PM
2002 Toyota Tundra
Hey thanks man :-)
For some people the torque may be important and maybe the outcome is different for different people. Wasn't trying to start an arguement, just trying to share what I did to get the sound I want and tell how you can do it too :-)
Old 11-26-2007, 10:12 PM
apimpdad's Avatar
2002 Toyota Tundra
Hey thanks man :-)
dont get me wrong, i loved the sound of my truck with no muffler, but with 38" tires i really need that low end torque to get rolling! if i could do this without losing the low end torque, i would do it in a heart beat!
Build Thread-
SAS on 02 Tundra
Old 11-30-2007, 08:58 PM
Dealer : Star Toyota
SmokeySevin's Photo Albums
Last Online: 10-05-2008 09:21 PM
SmokeySevin is on a distinguished road.
instead of utting off my mufler i installed a glasspack and dumped it after that and removed the resonator. i dropped about a tenth off my 0-60 which could have been due to any number of things but i definatly didnt lose any TQ.
SEAN
2001 AC SR5 4.7L i-Force V8
Tue Flow filter, Cherry Bomb Glasspack Dumped , Air Box Mod 2.0, Daystar 2.5 Inch Lift Kit, 285-75-16 BFG A/T, ASP Underdrive pulley, Debadged, PIAA Lights, Red Hoses, Infinity Reference Speakers, Sony XPLOD head unit w/ Bluetooth,s, 2 S8L5 subs under back seat powered by 800W Xplod Amp, Mb Blintz 16 inch wheels with Unique Centers, Bosch +4 platnum plugs, SSAUTOCHROME headers, Y pipe, 4.56 Gears, Royal Purple Fluids.
Old 12-01-2007, 12:21 AM
2002 Toyota Tundra
I don't know whether it's the larger tires using the higher RPMs, or I was really tired, or the 4 hours of driving.....but I think I'm gonna put my muffler back on now, lol
