Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Performance Exhaust Systems
Old 12-13-2008, 02:17 AM
Tundraman10's Avatar
Dealer : Toyota Of Boardman
2000 Toyota Tundra,
- Other - 1999 Chrysler 300M
Last Online: Today 02:38 AM
Images: 503
Tundraman10 is on a distinguished road.
Tundraman10's Photo Albums
Default should I remove the resonators
I just had this dumb idea pop into my head. I wanted to make my exhaust a little louder and I'm contemplating whether or not I should have the resonators removed. I live in ohio and emission and inspection are not to worry about because we do not have that in my county. Here is a clip of my exhaust. How much louder will the exhaust be once the resonators are removed?
YouTube - chrisced007's Channel
Chris
2000 Toyota Tundra SR5 Access Cab 4x4 Black
www.cardomain.com/id/tundraman10
http://www.tundrasolutions.com/galle...&cutoffdate=-1
Just call me Chris
Old 12-18-2008, 08:06 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: 11-17-2009 06:13 PM
Images: 64
Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all.
Highwaylizard's Photo Albums
Default Re: should I remove the resonators
It may be a little louder but I can tell you that you run a real risk of in cab drone. You can read my thread on what I did with mine Aero Turbine Exhaust.
The short end of it is this. I installed an Aero turbine muffler. In the process we cut out the stock resonator and ran a straight pipe back to the Aero turbine. The in cab drone at 70 mph and at certain rpm bands was absolutely intolerable. My wife went absolutely insane over this. I ended up having a glass pack installed in the original resonator's location and it took care of the problem. I still get a nice growl/rumble but no more in cab drone and no more wishing I could beat myself to death with a hammer on long trips with the wife.
I think you would be best served if you could find a truck whose exhaust you like and then find out what kind of muffler they are running. Leave the stock resonator in place and just get a good muffler to replace the one you currently have.
On a personal note, I have always been curious what it would sound like if someone cut out the stock resonator and the stock muffler and replaced each one with a glass pack. It would be one glass pack feeding into a couple of feet of pipe and then into the other one - not dual pipes with a glass pack on each.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires.
testis amotio per pera
150,620miles on the odometer Tundra Fuel Economy Blog
19+ MPG on the Highway at 75 MPH in a DC with a four speed automatic and a bad O2 sensor - not too shabby!
Old 12-18-2008, 08:15 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: 11-21-2009 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Don't do it Chris. Get a new flow-through design muffler if you're seeking louder exhaust.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 12-19-2008, 06:29 PM
Negra's Avatar
Last Online: 11-21-2009 09:04 AM
Negra is a splendid one to behold. Negra is a splendid one to behold. Negra is a splendid one to behold.
Negra's Photo Albums
EXACTLY !
Classic Chambered Exhaust Inc. - Home Page
Corvette Exhaust System, Sidepipes, Mufflers - Sweet-Thunder.com - Chambered General - Main page
Stainless Works
I care not who defended our freedom in the past, who defends it tommorrow is who means the world today.
The trouble with the world is not that people know too little, but that they know so many things that ain't so
- Mark Twain
