In about a month I will be heading over to a local muffler shop to get a custom exhaust system made for my Tundra. I wanted to know what you guys thought would be an optimal setup for my 4.7L RCSB. Here's what I had in mind:
-Dual 2.25" piping (not sure what material yet )
-H-pipe
-Magnaflow or Borla mufflers (open to suggestions on that) with dual rear exit behind the passenger side tire
I'm thinking about leaving the cats out entirely or just getting hi-flow cats. I'm afraid that it might be too loud though.
My goal with this system is a nice, aggressive tone with a deep rumble at idle (I want to make my presence known ) but nothing too loud. Low-end torque is a priority. What do you recommend?
__________________ '07 Slate Metallic SR5 RCSB
4.7L V8, 2WD
TRD Off-Road package K&N Cold Air Intake Doug Thorley> Headers Tundra Racing TR1040 Drop Kit
OEM Fender Flares
20" Limited wheels
Custom dual exhaust system coming soon
Secondary Cat delete,true dual PowerSticks #22530SB(2.25X26")Classic Chambered Exhaust Inc. - Products
Dual right exit with 3" straight cut tips.
Aluminized steel will last you a good while in Fla.
FWIW You cant buy aftermarket cats that are any better then the stock ones you already have.
Your Sig references DT Headers ? they on there or not ?
I care not who defended our freedom in the past, who defends it tommorrow is who means the world today.
The trouble with the world is not that people know too little, but that they know so many things that ain't so
- Mark Twain
I think I will be ordering the Powersticks then. But my biggest worry will be drone and noise level. I don't want my truck to sound obnoxious or drone loudly while cruising.
4.7L V8, 2WD
OEM Fender Flares
20" Limited wheels
-H-pipe
If low end torque is a priority, I would not run a dual setup. I reccomend having a y pipe made to instigate a scavaenging effect, with a 3" mid pipe into a Flowmaster or Spintech muffler with a single tailpipe. 2.5" for the most low end torque, 3" for mid range to top end HP.
Very Poor Advise.
There is no need for scavenging on a
DUAL VARIABLE VALVE TIMING IFORCE 4.7 or 5.7
Spintech and Blowmaster both droan pathetically
- Mark Twain
