Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires. testis amotio per pera
I am not sure that I understand what you are trying to do. If you are not running duals then there is no need for an h-pipe. Are you referring to a y-pipe?
