Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Performance Exhaust Systems
Old 06-27-2009, 04:17 PM
RBLTOY's Avatar
Dealer : Toyota of Elizabeth City
2004 Toyota Tundra
Last Online: 11-18-2009 07:38 AM
Images: 30
RBLTOY is on a distinguished road.
RBLTOY's Photo Albums
Default JBA Header install in progress -- Need help
Hey guys...i am attempting to remove the passengar side manifold but am having issues with the nut that is inbetween the manifold and motor mount....does anyone have any suggestions on breaking this one loose? I have tried getting a ratchet but theres just not enough room and a wrench is doing nothing but rounding out the head of the nut...let me know how you guys did it...thanks much
-Lift- 3" Body Lift -- 3" Fabtech Coilover w/ AAL -- 1" Diff Drop -- Total Chaos UCA's -- TC Steering Rack Bushings
-Performance- Unichip -- JBA Headers -- Flowmaster Dual exhaust w/o resonator -- K&N Aircharger kit -- 4.88's Front & Rear -- Rear Detroit Locker
-Wheels - 315/75r16 Cooper Discoverer STT's on Procomp 1069 alloys
-Misc Mods- 20% window tint -- Black Euro Tail lights -- Line-X Bedliner -- Superlift Truspeed Calibrator
Old 06-27-2009, 04:49 PM
nedjames's Avatar
Dealer : Yokem Toyota
Last Online: Yesterday 05:26 PM
nedjames is on a distinguished road.
nedjames's Photo Albums
Default Re: JBA Header install in progress -- Need help
I have a 2001 and don't know how different yours is, but I removed the motor mount. Put a piece of wood between your jack and the oil pan and just give it a little bit of lift. My mount only had four bolts. It gives you the room you need.
Old 06-27-2009, 05:15 PM
saki302's Avatar
Dealer : Toyota of Glendale
Last Online: 11-18-2009 07:51 AM
Images: 10
saki302 is on a distinguished road.
saki302's Photo Albums
I was told on the newer trucks you have to loosen the motor mounts and jack the engine up slightly on one side to access the one bolt.
-Dave
Old 06-27-2009, 05:49 PM
RBLTOY's Avatar
2004 Toyota Tundra
Images: 30
Welp, after taking a peek at it i have a feeling that that is the only option, i just hope that the one bolt head isnt stripped to the point of a ratchet not grabbing it now. Will let you guys know...thanks for the tips.
Old 06-28-2009, 03:58 PM
RBLTOY's Avatar
2004 Toyota Tundra
Images: 30
Welp so far the passenger side is complete the driver side is still a work in progress, however due to a 1/2 drive universal as well as a 3/8's universal snapping the job is coming to a halt for now...kinda sucks though because the drivers side had to be grinded off (the receiver pipe not the manifold part...) anyway...good thing the universals were craftsman...gonna have to take em back to get replaced before i can finish the job
Old 06-28-2009, 08:55 PM
saki302's Avatar
Images: 10
Talk to Gutz- he did his pretty much by himself in around 3 hours.
-Dave
Old 06-28-2009, 10:05 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Yesterday 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
I feel your pain bro. The driver's side is the worst, especially those two studs hidden under the motor mount. I completely removed my motor mount and had decent access to the studs. It wasn't great, but it was good enough to get the proper tools in there through the wheel well. Breaker bars, all sizes of universals, about 2ft of extension and every 14mm socket I could find, as well as a few 14mm open/closed end wrenches and a ratcheting combo wrench.
From what others have told me, if you can get a torch in there (with confidence), heat the studs and then break them loose. Seems that's the best way to go.
Good luck!
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 07-02-2009, 05:16 PM
Dealer : Courtesy Toyota Scion of Brandon
2005 Toyota Tundra
Last Online: 09-04-2009 05:11 PM
Images: 4
tundrajoel is on a distinguished road.
tundrajoel's Photo Albums
just finished my header install today i work at a dealer ( honda) and used a lift , air tools, almost every socket,extention,swivel combo you can think of and i cut out my y pipe and resinator welded in new y pipe from kit pain in the *** install but it sounds good
2005 dc 4x4, boost brothers headers & Y-pipe flowmaster, k&n intake , diff drop, 5100's set on high, 285-75-16
Old 07-03-2009, 10:50 AM
RBLTOY's Avatar
2004 Toyota Tundra
Images: 30
yea i ended up finishing it up on wednesday, i snapped both my half inch and 3/8 craftsman universals while i was taking the manifolds off...most def wasnt the highlight of my install...although it was to be expected, after 5 years of all different types of mud on the bolts 5 of the studs wouldnt even budge so i had to use a combination of the new lugs and the factory studs to reinstall the headers. I actually found the passengar side to be harder to get to then the drivers side on mine, however the body lift made it quite a bit spacier around things. all in all the install is clean, it was a pain to actually get the drivers side header into position, but it is done. I can def feel a low end power loss and a slight gain in higher end, hopefully when i send the unichip back to them to have it reprogrammed, it will give gains all around.
Old 07-03-2009, 11:37 AM
Gutz's Avatar
Diplomacy is dead!!!
Dealer : Fletcher Jones Toyota
2007 Toyota Tundra 5.7 RC/SB
Last Online: Yesterday 12:16 PM
Images: 15
Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything.
Gutz's Photo Albums
Where are the pics man?!?!?
iF57 Tundra Racing Club
Old 07-03-2009, 12:51 PM
Images: 205
Good to hear you got it all hooked up. I figured the body lift would help with clearance. Let your ecu adjust while you flog the skinny pedal!
