Re: Can someone look up a VIN for me?
Model Number: 8361A SERIAL # :8X074232 Check Code: 1
Model Description: CMAX 5.7L V8 Category ..........: G
Year ............: 2008 Current Dealer ....: 110-04061
Interior Color ..: FL13 FL13 Wholesale Dealer ..: 04061
Exterior Color ..: 0040 WHITE Previous Dealer ...: 00110
Body ............: C/MAX 5.7L TUN-GRADE Invoice Date ......: 06/13/08
Number of Cyl ...: 8 Ship Date .........: 06/16/08
Allocation Number: 061 Retail Date .......:
Engine Number ...: 5283591 Date of First Use .:
Vessel Number ...: 721 TRAC ..............: NO
Vessel Name .....: TMMTX SANANTONIO Damage ............: NO DAMAGE
PDI ...............: YES
Fleet .............: NON-FLEET
Port PDS Complete .: NO
VIN .............: 5TFDV54178X074232
Ignition Key.....: N/A
Factory Installed Accessories: FE CK EV CB HM ST TO
Port Installed Accessories ..: C4
Retail Dealer
Vehicle Base Model ....................: $ 31935.00 $ 27943.00
Total Accessories .....................: $ 1105.00 $ 861.00
MECHANICAL & PERFORMANCE
GVWR = 7200 lbs. Payload = 1590 lbs.
Tow Capacity = 8100 lbs.
381HP/401 Lb-Ft 5.7L DOHC 32V iForce V8
w/Dual Independent VVT-I and ACIS
6-Spd Automatic Trans w/Sequential Shift
Engine Immobilizer, Cruise Control
4WDemand 4x4 System w/Electronically
Controlled 2 Speed Transfer Case
4.10 Rear Differential w/10.5" Ring Gear
Automatic Limited Slip Diff (Auto LSD)
TripleTech Frame: Fully-boxed Fr Section
Reinforced C Under Cab, Open C Under Bed
Coil Over Shock Double A-Arm Front Susp
Multi-Leaf Trapezoidal Rear Suspension
w/Staggered Outboard Mounted Shocks
18" Steel Wheels w/P255/70R18 Tires
Pwr 4 Wheel Disc Brakes, 13.9" Fr Rotors
EXTERIOR
Double-Walled Bed w/Tailgate Assist
Black Handles, Outside Mirrors
Color-keyed Front Bumper
Chrome Grille Surround, Rear Bumper
INTERIOR
40/20/40 Front Bench Seat w/8-way Dr &
4-Way Fr Pass Adj, Center 3pt Seatbelts
Dual Zone Climate Control w/Sync Mode
AM/FM/CD w/6 Speakers & Aux Audio Jack
Tilt Steering Wheel
Power Windows/Door Locks/Mirrors
Cloth Trimmed Seats
Remote Keyless Entry System
Variable Intermittent Windshield Wipers
SAFETY
STAR Safety: Pwr Assist 4 Wheel Disc ABS
w/Electronic Brakeforce Distrib (EBD),
Brake Assist, Vehicle Stability Control
with Active Traction Control (VSC+ATRAC)
Dr & Fr Pass Advanced Airbags/Seat Side
Airbags/3 pt Seatbelts w/Pretensioners
& Force Limiters
Roll-Sensing Curtain Airbags (RSCA)
Tire Pressure Monitoring System
Retail Dealer Total
Vehicle Base Model ..........................:$ 31935.00 $ 27943.00 $ 31935.00
50 State Emissions .........................
Cold Kit: Heavy Duty Battery, Heavy Duty ... 160.00 128.00
Starter, Windshield Wiper De-icer with .....
Timer, Front and Rear Mudguards ............
AM/FM CD Audio w/6 Speakers ................
Chrome Front Bumper ........................ 30.00 24.00
Power Heated Outside Mirrors ............... 30.00 24.00
18" Styled Steel Wheel ..................... 110.00 88.00
Tow Package: 10,100 lbs. Towing Capacity / . 660.00 528.00
1,515 lbs. Payload Capacity. Hitch ........
Receiver, Supplemental Transmission ........
Cooler, Tow/Haul Mode, 4.30 Rear ...........
Differential with 10.5" Ring Gear, 150A ....
Alternator, Transmission Temperature .......
Gauge, 7 Pin Connector, Trailer Brake ......
Controller Prewire .........................
Carpet Floor Mats - 4 piece ................ 115.00 69.00
Total Accessories ...........................: $ 1105.00 $ 861.00 $ 1105.00
Destination Charge ..........................: $ 685.00 $ 685.00
TDA .........................................: $ 349.00
Gasoline ....................................: $ 10.00
Dealer Holdback .............................: $ 638.00
Whsl. Financial Reserve .....................: $ 319.00
Total .......................................: $ 30805.00 $ 33725.00
Model Number: 8361A SERIAL # :8X073249 Check Code: 6
Body ............: C/MAX 5.7L TUN-GRADE Invoice Date ......: 05/24/08
Number of Cyl ...: 8 Ship Date .........: 05/28/08
Allocation Number: 051 Retail Date .......:
Engine Number ...: 5280821 Date of First Use .:
Vessel Number ...: 720 TRAC ..............: NO
VIN .............: 5TFDV54188X073249
Retail Dealer
EXTERIOR
INTERIOR
Tilt Steering Wheel
Cloth Trimmed Seats
SAFETY
& Force Limiters
Retail Dealer Total
Now a sales manager at Stafford Toyota in Stafford VA. Call 540-720-4700 and ask for Steve Clifford... they will not know who "Cliffy" is.
