12-28-2008, 10:01 PM
- Other - 07 Suzuki DRZ400SM, 2007 Toyota Tundra Silver Sky RCSB
Last Online: 11-15-2009 08:04 PM
2
FAQ: Disabling Vibrant Advertising
Does anyone else have these stupid Vibrant advertising links on this forum? I don't have it on any other forum I am on, just TS and it is annoying as hell. Is there any way to get rid of them?
Thanks.
Steve
2007 Tundra RCSB Silver Sky Base Model
Mods: Avic 900BT, 6.5 doors, 6x9 rears, 2 Kenwood 12" subs, Dynomat doors, Python alarm, remote start, and P/L, AVS bug sheild, color matched tailgate handle, tonneau cover
12-29-2008, 06:52 AM
Dealer :
Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 02:18 PM
17
Re: Vibrant advertising
To disable the text link ads, simply follow these directions.
In the top Navigation bar click on the user CP.
Once opened then click on "Edit your Details".
Scroll down to the 3rd box which should be "Additional Information".
In that Box you will see "IntelliTXT Ads" Check disable scroll to the bottom of the page and save. You just turned off the ads.
~Glenn
12-29-2008, 08:03 AM
Assistant Administrator
2005 Toyota Tundra AC 4.7L 4WD, 2004 Toyota RAV4 Sport 2.4L 2WD
Last Online: Yesterday 09:35 AM
10
The disable feature that nhparrot pointed out is a cookie. If you have cookie's disabled or clear-cookies after each session, you will have to disable vibrant each time you logon to IE7.
My Truck: 2005 Tundra , 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP. Suspension & Tires: 285/75-16 BFG T/A'ko , Fabtech Coils, 1.5" Wheeler's blocks , Toytec Diff Drop , 1.25" Spidertrax [front] , 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links , Wheeler's Anti-Sway Kit , Hellwig 7700 Swaybar , Timbren Rear SES
Electrical: URD MAF Sensor Calibrator , Superlift Truspeed Speed Sensor Re-Calibrator , ScangaugeII , Full LED Conversion
Stereo: Alpine CDA-9886 , Alpine & Phoenix Gold amps, Q-Logic box w/RF subs , eDead
Cosmetic: Line-X Bedliner , Custom N-Fab Steps , Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve , Debadged (partially ), Bell Truck Trunk, Access Vanish Tonneau
B e an organ & tissue donor, register at Donate Life
Linear Mode
