Re: Where'd the cars in "My Garage" go?
They're still there. You may not be seeing them sometimes when you use the Post Quick Reply, Photo Gallery Posts, and in Private Messages. The system used for the My Garage loads slower than those three things post, so it doesn't get loaded. The Quick Replies will show your garage the next time you load the page/thread.
To access the My Garage to make changes, simply click the My Community from the ribbon (the header near User CP), and in the drop down menu, click My Garage. You can add vehicles and track maintenance logs there.
Hope that helped. If not, let me know.
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
