Squeak, squeak, squeak,...
+ Reply to Thread
Results 1 to 8 of 8
Thread: Squeak, squeak, squeak,...
  1. #1
    Join Date
    Jun 2007
    Location
    Martinsville, VA
    Posts
    67
    Liked
    0 times
    Rep Power
    0
    Default Squeak, squeak, squeak,...
    I have searched and searched and have been unable to find the cricket chirp in my '03 Tundra. Every little bump equals a chirp. ANy ideas?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member JBK23's Avatar
    Join Date
    Sep 2007
    Location
    Macon, GA
    Age
    56
    Posts
    2,417
    Liked
    1 times
    Images
    10
    Rep Power
    54
    Default Re: Squeak, squeak, squeak,...
    Might need better shocks for the truck or the ones you have might be bad.
  4. #3
    Lurking Member TRD'stundra's Avatar
    Join Date
    Sep 2007
    Location
    SD
    Posts
    33
    Liked
    0 times
    Rep Power
    9
    Try pushing down your rear bumper. If it squeaks then it should be your rear leafs wich is normal if your truck goes off roading...
    03 Tundra v8 4wd
    JBA headers, exhaust and y-pipe, cold air intake, upgraded sloted cross drilled rotors, upgraded off road sealed starter from trd, 265/70 bfg a/t, optima red top and more comming soon
  5. #4
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1527 times
    Rep Power
    269355
    There are four rubber lined steel clampy things holding your rear leafs together. If these clamps become spread apart, it allows the leafs to move against each other more than they should, which produces noise. I just use a large c-clamp to squeeze the clamps together.
  6. #5
    Join Date
    Jun 2007
    Location
    Martinsville, VA
    Posts
    67
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Mine are really spread apart. I'm gonna try this.
  7. #6
    Veteran Member Jetes03tundra's Avatar
    Join Date
    Jan 2006
    Location
    VA
    Posts
    1,955
    Liked
    1 times
    Rep Power
    11
    i have this squeak up front too..im thinking it might be the shocks, but it goes away everynow and then so ill wait alittle bit longer
    2006 silverado with full bolt on's and its fast
  8. #7
    Supercharged Member apimpdad's Avatar
    Join Date
    Aug 2006
    Location
    Polk County, Florida
    Age
    26
    Posts
    2,992
    Liked
    166 times
    Images
    62
    Rep Power
    6833
    i had a squeak up front one time, it ended up being the bumper. a screw/bolt that was on the passenger side (no the ones that hold the bumper to the frame, just a random one on the backside/inside of the bumper) had come loose and squeaked. all i did was tighten it and it went away.
    New Truck Build Thread 2006 Double Cab
    http://www.tundrasolutions.com/forum...dra-build-2-a/
    New Build Thread 2002 Tundra-Tundra Revamp
    http://www.tundrasolutions.com/forum...tundra-revamp/
  9. #8
    Join Date
    Jun 2007
    Location
    Martinsville, VA
    Posts
    67
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Well, I finally found it. It is in one of the bushings on one of the rear shocks. Me and WD-40 just found it.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Rear suspension squeak
    By jploski in forum Suspension, Axles, Brakes
    Last Post: 10-17-2010, 10:38 AM
  2. squeak noise
    By klostman in forum 1Gen-Tundra
    Last Post: 01-12-2007, 11:07 AM
  3. Squeak Squeak Squeaky pulley
    By principalboy in forum 1Gen-Tundra
    Last Post: 11-13-2006, 07:51 PM
  4. Push on the bumper...get a squeak!
    By Malachi in forum Suspension, Axles, Brakes
    Last Post: 10-10-2005, 02:36 PM
  5. Tundra Leaf Spring Squeak
    By klaatu in forum Suspension, Axles, Brakes
    Last Post: 02-21-2005, 07:38 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
