This is a discussion thread titled "2.5" Daystar lift and AAL.. RUINED RIDE??", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 10-08-2007, 01:16 PM
Dealer : Mossy Toyota Scion
2004 Toyota Tundra
Rob426's Photo Albums
Last Online: 06-19-2008 04:24 PM
Rob426 is on a distinguished road.
Thumbs down 2.5" Daystar lift and AAL.. RUINED RIDE??
I have searched and read several posts, but have to get more specific..
I Installed a 2.5" daystar spacer with add-a-leafs in back. My ride quality suffered severely. I don't know about all you, but to me, the smooth ride of my stock tundra was nice to have. Anyone else notice this? It is now a hard, bouncy ride.
If I remove the AAL's, will my rear end sag? Whay about carrying a load (which I do for work) Do the front spacers "pre-load" the spring and amke it that much stiffer?
I am tempted to remove the entire level lift, though I love how it looks. Would upgraded shocks cure my ride woes?
Bottom line: I want that factory lexus-like ride. Not concerned with off-road abilities, but need to carry a load w/ work equip.
Any suggestions/ comments appreciated, thanks!
'04 TRD Tundra limited access cab. 265/70/16 (stock size) BFG AT's, properly inflated
Old 10-08-2007, 02:28 PM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Today 01:58 AM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
Default Re: 2.5" Daystar lift and AAL.. RUINED RIDE??
if you want a smoother ride, remove the daystar and get some donahoe or sway a way coilovers for the front. they are expensive though...
2002 Tundra-SAS-Dana 50-Sterling 10.5-Inchworm 2.28 Dual Transfer Case-4.56 Gears-38.5 Thornbirds-ASP Underdrive Pulley-Flowmaster Muffler
Build Thread-
SAS on 02 Tundra
Old 10-08-2007, 03:34 PM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
longwoodklon's Photo Albums
Last Online: Yesterday 04:57 PM
longwoodklon is on a distinguished road.
The Daystar has 2 pieces, right? part of the spacer is inside the coil pack and another piece is outside the coil pack, right? Honestly, this has been gone over many times. Sure a coilover is the best, but a spacer usually doesn't make the suspension that objectionable. I can see if the entire spacer is inside the coil pack. Then again, the simple fact that you are increasing the a-arm angle itself makes the ride stiffer.
Still, I doubt the front is the problem. I can tell you I added an AAL in the back and there are some parts of the freeway were it bounces pretty good. First thing you should try is remove the AAL and add a block back there, that should get the rear back to normal. If you are worried about sag, seems like airbags are the best bet.
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 176k miles and counting......
Old 11-02-2007, 02:15 AM
Dealer : Carson Toyota Scion
markcervi's Photo Albums
Last Online: 10-01-2008 09:47 PM
markcervi is on a distinguished road.
longwoodklon,
I was thinking about installing the 1" Daystars since I need to buy new tires anyway. How well do your 285/75 BFG's fit and ride?
White 2000 Tundra TRD 4.7L V8 4x4
- Camburg 2.5" Coilovers
- Camburg UCA's
- 1" Differential Drop
- 4.30's
- Ivan Stewart Wheels
- 285/75/16 Toyo Open Country A/T's
- Spin Tech Muffler
Old 11-03-2007, 12:35 PM
Dealer : New Rochelle Toyota
reldapimp's Photo Albums
Last Online: 11-27-2008 10:23 AM
reldapimp may have some regrets.
well to see if you like the front. drive over a speedbump at a decent speed and see if you like the results.
Old 11-05-2007, 11:58 AM
2001 Toyota Tundra,
2005 Toyota Sienna
Originally Posted by markcervi View Post
longwoodklon,
You won't be able to fit 33's with just the 1" spacer. I did the 1" spacer with 4x4 coils, so it raised it ~2.75 inches. /Mike
