Alignment Specs - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: Alignment Specs
  1. #16
    Rookie CEDevils is on a distinguished road.
    Join Date
    Mar 2012
    Location
    Mildenhall, UK
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Default Re: Alignment Specs
    Ok so I called my Toyota Dealership from England and they sent me the factory alignment specs for my 2010 Tundra (US Spec). Here they are:
    Toe-in - 3.69 +/-2.0 mm (0.145 +/-0.0787 in.)
    Inside wheel angle- -39º27'to -42º.27'
    Outside Wheel Angle- 36º48' (36.80º)
    Camber Inclination- 0º14' +/-45' (0.24º +/-0.75º) 30' (0.50º) or less Caster Inclination- 2º35' +/-45' (2.59º +/-0.75º) 30' (0.50º) or less Steering Axis Inclination- 12º46' +/-45' (12.77º +/-0.75º) 30' (0.50º) or less
    I hope this helps everyone out. I will post up the results of my alignment soon!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    DJ
    DJ is offline
    Supporter DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points.
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,014
    Liked
    174 times
    Rep Power
    8592
    At your local alignment shop, the wheel alignment system console has an internal database of manufacturer's recommended alignment specs. Trust me, the make/model/variation of your particular vehicle will be in that database. They are amazingly complete and go back a good many years. Any alignment shop should be able to provide you with those specs.
  4. #18
    Join Date
    Mar 2012
    Location
    Mildenhall, UK
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    I am posted in England for the military. Both the bases here have computers which give them alignment specs. Here in England my truck is too heavy for the base lifts so I am forced to go off base. Because the tundra is not sold in England I had to call back to the states to get the specs. That is all. Thanks for the info though!
    Sent from my iPhone using AutoGuide.com Free App
  5. #19
    DJ
    DJ is offline
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,014
    Liked
    174 times
    Rep Power
    8592
    Ah, yes, you stated that you called from England. I did not know that the Tundra was not available there, and so the specs might not be in the database for that area. Mea culpa.
  1. 04-03-2012, 10:56 PM
  2. 05-06-2009, 09:06 PM
  3. 01-20-2009, 04:26 PM
  4. 08-28-2008, 07:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
