Originally Posted by
DJ
Compensating for road crown is a holdover from the days when roads were two lanes wide (one lane each direction) and so the road always sloped to the right side of the car. With modern freeways and such, that is often not the case.
Moreover, compensating for road crown is a technique that could provide some benefits if the vehicle were sensitive to road crown in the first place. The whole point of my recommendations for specs is to set caster as high as Toyota's specs for the Tundra recommends, thus providing the maximum steering stability and the minimum sensitivity to road crown that those specs allow.
So, your Tundra doesn't need any compensation for road crown. Mine has 101,xxx miles and seven years on it, all without any such compensation, and has never pulled either way due to road crown.
Your alignment could be better, and I would realign it if it were mine.
Toe is always measured (with modern equipment, that is) as an angle, but it can be reported as "degrees", "inches", or "millimeters". The standard conversion used in this country is that two degrees of toe equals one inch of toe.
