Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 10-21-2007, 07:25 PM
tundraboy27909's Avatar
Dealer : Toyota of Elizabeth City
2000 Toyota Tundra,
2005 Toyota 4Runner,
2006 Toyota Tacoma DCab TRD Off Road
Last Online: 11-11-2009 09:42 AM
tundraboy27909 is on a distinguished road.
tundraboy27909's Photo Albums
Default Question about compressing coil/removing top plate
I am trying to remove the top mounting plate on my coils.
I have compressed the coil spring and am trying to remove the nut that holds the top mounting plate on so that I can install longer studs for a spacer.
When I turn the nut that holds the top mounting spacer onto the coil the shock shaft moves along with it making it impossible to remove the nut.
Is this normal?
Does anyone have any idea how to fix this?
Did I miss something?
Old 10-21-2007, 07:34 PM
MOREPOWER's Avatar
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
MOREPOWER's Photo Albums
Default Re: Question about compressing coil/removing top plate
Is this normal?
Its normal for the shaft to turn, use a vice grip on the portion above the nut, or a wrench, theres a flat spot for this at the end of the shaft, this will allow you to remove or at least loosen the nut. Hope this helps.
Old 10-21-2007, 09:13 PM
Dealer : Desert Toyota Scion Of Tucson
Last Online: 06-16-2008 01:31 AM
CoyoteAZ is on a distinguished road.
CoyoteAZ's Photo Albums
Impact gun will take care of it quickly.
Old 10-28-2007, 03:19 PM
2000 Toyota Tundra,
Impact gun does seem to be the most effective method. The shaft will still turn but the impact gun will spin the nut faster than the shart turns so the nut spins off.
Old 11-07-2007, 12:44 PM
slamdyota's Avatar
Last Online: Today 12:58 AM
slamdyota is on a distinguished road.
slamdyota's Photo Albums
always best to break the top nut loose before taking the whole setup out of the truck
