rear shock poly bushings
Where can I get a set of polyurethane bushings for the rear shocks and leaf springs? The rear end is now starting to make a lot of noise and before I start replacing anything major (leaf springs, shocks, etc) I wanna see if the degraded rubber is whats causing the noise.
01 Toyota Tundra
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
