This is a discussion thread titled "crooked steering wheel - alignment issue", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-04-2008, 11:46 PM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
wirelessf's Photo Albums
Last Online: Today 12:00 AM
wirelessf is on a distinguished road.
Default crooked steering wheel - alignment issue
I finally got the steering rack bushings replaced with polyurethane bushings. However the steering wheel is now crooked to the left whenever I go straight. Do I need to get an alignment job done?
Also I did some searching on DJ's alignment specs and was wondering how could I bring my truck to those specs when I bring it to the alignment shop?
01 Toyota Tundra 2UZ-FE
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
1990 Toyota 4Runner 3VZ-E
Smittybilt Grille Guard - K&N drop in
Old 04-05-2008, 04:39 AM
Dealer : Nye Frontier Toyota/Scion
2004 Toyota Tundra Limited
asjch3's Photo Albums
Last Online: 11-26-2008 03:44 AM
asjch3 is on a distinguished road.
Default Re: crooked steering wheel - alignment issue
Most any time you mess with the suspension or steering, an alignment will need to be done. When I put my poly bushings in, my steering wheel stayed straight but the truck would vere to the right. I drove it like that for a week or so until I got my coilovers in, then got the whole thing lined up. Good as new.
Old 04-08-2008, 11:46 AM
semcoll's Avatar
Dealer : Panama City Toyota Scion
semcoll's Photo Albums
Last Online: Yesterday 02:40 PM
semcoll is on a distinguished road.
You don't need an alignment per se, since camber/caster remain the same, you just have to have the steering wheel centered. This is done by resetting the toe-in. You may save a few bucks by only having the toe reset.
5.7L 2WD DC Salsa Red Pearl SOS 2/4 drop, 18" Enkeis w/BFGs, TRD anti-sway bar, Hella Optilux driving lights, Flowmaster 50 dual in/out w/baffled Hooker tips, LineX, DeeZee black diamond toolbox,filled color-matched grille shell w/CarriageWorks insert, Blacked-out headlights, Beltronics 955 radar unit
http://seminolecollision.com/
Old 04-08-2008, 02:17 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Today 12:06 AM
HOGWILD will become famous soon enough.
FSM says allways check alignment after this type of procedure, tell the Tech you want an alignment sheet print out for your records and tell him what specs you would like him to set the adjustments to and if he says no, go somewhere else. Correcting steering wheel alignment should allways be done during alignment which should be done every 10K or once a year. Toyota alignments are only 69 bucks out here!
