This is a discussion thread titled "Rear suspension torque specs?", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
Hey all - I'm doing my rear AAL today (front spacers tomorrow, assuming I don't hit anything too screwy on the rear!).
I need to know the factory torque specs for the leaf spring centering bolts, the u-bolts, and the lower shock mounting bolts.
I searched and found this thread: Torque on Leaf Spring bolts, which says 98 ft-lbs for the leaf spring bolts and u-bolts - is that correct? What should I use for the lower shock mounting bolts?
I am looking in the manual for an 03 Tundra.
It says:
Install spring center bolt and nut @ 33 ft. lb.
Install the shackle and leaf spring with 3 bolts, washers and
nuts @ 125 ft. lb.
Install U-bolts with 4 washers and nuts @98 lt. lb.
Install lower Shock bolts @64 ft lb.
Install nut on top of shock at 15 ft lb.
Shackle bolts and nuts @125 ft lb
I hope this helps. Good luck.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Nav system, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Line, 5.7 Killer
