Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 04-29-2008, 05:25 PM
TundraZone2001's Avatar
Dealer : Star Toyota
2004 Toyota Tundra
Last Online: 01-22-2010 01:54 PM
TundraZone2001 is on a distinguished road.
Send a message via AIM to TundraZone2001 TundraZone2001's Photo Albums
Default Reasonably priced suspension lift for 04 Tundra 2WD access cab
Hey guys,
I've been researching some, and don't want to shell out $2400+ for the RCD 4-6" lift. I'd still like a 3-4" lift, but was looking to spend about $1500(max), installed. At the same time of doing the lift, I will buy some 15" wheels(like these- http://eastsidecustomtruck.com/i-60210-black-rockcrawler-rims-15-3-45-bs.html) along with 33" tires.
Thanks in advance for all the help!
-Clay
Old 04-29-2008, 06:45 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 04:48 PM
Images: 22
DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous. DevinSixtySeven is more than famous, they're infamous.
Default Re: Reasonably priced suspension lift for 04 Tundra 2WD access cab
Hey Clay! Welcome to the forums .
Unfortunately those wheels don't clear the caliper width in any size (at least without grinding the caliper ...it's been done but wouldn't ever recommend it!), and ya gotta run a 16" rim or larger to clear the caliper diameter.
If you need an inexpensive rim, American Racing is usually a good deal...I got a set of 16x8s for under 100/rim, also a set of 17x10 for about 130/rim but don't remember the manufacturer.
There are quite a few size and width combinations that will work with the stock suspension, both wheels and tires.
Try the Bilstein 5100 kit with a body lift and you should be able to accommodate up to a 35x12.5R16 tire.
-Sean
GFX by FreedomEagle50
Manual Hubs
