This is a discussion thread titled "Why most spacer lifts are bad....", within the Suspension & Axle forum, part of the Technical & Vehicle Assistance Forums category.
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 05-19-2008, 05:52 PM
Preferred Dealer
jzaiden's Photo Albums
Last Online: 11-29-2008 05:32 PM
jzaiden is on a distinguished road.
Default Why most spacer lifts are bad....
I get trucks into the shop from time to time with spacer lifts on them. There are three different types of spacer lifts.
1) The kind that just space the shock down to get lift. i.e. they space the shock down 2" you get a two inch lift. The problem with this type of spacer lift is the ball joints will bind at droop causing the ball joints to wear out very quickly or can cause the ball joint to just break!
2) The next type of spacer lift is the kind that pre-loads the factory spring with the factory shock tuned for the factory spring rate. The problem with this setup is you get lift but now your shock tuning will be very bouncy.
3) Third is the combo drop the shock down and pre-load the spring spacer. This just gives you the best of both problems.
PEOPLE IF YOU ARE GOING TO LIFT YOUR $20,000-$40,000 truck don't skimp on suspension!
I am only writing this because we took off a spacer lift to replace his kit with a Camburg 2.5" coilover and UCA. His alignment shop told him his ball joints were worn out and he needed new ones. After he was quoted the price to just replace the upper stock ball joints he came to us to set his truck up correctly.
Here are pictures of his spacer lift and his blown out ball joints. Notice they are blown out from drooping not bottoming out! His truck does not even look like he has used it off-road!
Old 05-19-2008, 10:00 PM
Imdone's Avatar
2004 Toyota 4Runner,
My eBay Imdone's Photo Albums
Last Online: Yesterday 03:48 PM
Imdone is on a distinguished road.
Default Re: Why most spacer lifts are bad....
Nice picks Jerry!
Spacer =
Coilover =
Work in progress...
Old 05-19-2008, 10:03 PM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Today 01:58 AM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
Wouldn't the same thing happen to the ball joint if he was running a coilover too with the stock UCA?
2002 Tundra-SAS-Dana 50-Sterling 10.5-Inchworm 2.28 Dual Transfer Case-4.56 Gears-38.5 Thornbirds-ASP Underdrive Pulley-Flowmaster Muffler
Build Thread-
SAS on 02 Tundra
Old 05-19-2008, 10:27 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Today 12:34 AM
No, the aftermarket kits meant for stock arms are no longer than the stock coilovers, or at least no longer than the additional maybe 3/4" wheel travel lthat the stock joint allows. Bilstein 5100s work that way. I've heard a couple places that Kings are actually slightly shorter.
GFX by FreedomEagle50
Manual Hubs
Old 05-19-2008, 10:52 PM
apimpdad's Avatar
2002 Toyota Tundra
Doesn'tmake sense to me, but I have never been up to par on my coilover stuff . I think I understand a little.
Build Thread-
SAS on 02 Tundra
Old 05-19-2008, 11:32 PM
Preferred Dealer
The coilovers will be around 1/2-1" longer but not 2" longer. The coilovers are also solid because they use a spherical bearing and no bushings. The after market shocks with bushings will pull on the bushings at droop and also allow the upper ball joint to bind. The shocks limit the droop so if they are to long your droop travel will not be limited correctly.
I have a challenge for those with a spacer kit. This will only take a few minutes for most. Go remove the spiral snap ring off the ball joint boot and see if your spacer kit is allowing the upper ball joint to bind. If it is this is very dangerous!
Old 05-20-2008, 01:05 AM
Imdone's Avatar
To make it simple and the way I understand it!
If the coilover is not under pressure and is (for arguement sake) 10" long, then the UCA and LCA ball joints allow a droop of 11" long you don't have any problems.
However if you add a 2" spacer to the top of the coilover you are now making the relaxed, drooped, unsprung length of the coilover 12" long.
This is 1" greater than the UCA and LCA ball joints can handle and begin to bind.
The after market coilovers are 11" long but the spring compression is adjustable and therefore allows the truck to ride at a taller height. All the while it doesn't actually put the ball joints into any bind because they are not longer than the UCA and LCA ball joints can handle.
Hope this helps.
Work in progress...
Old 05-20-2008, 07:22 AM
imjin's Avatar
Defiant ut Terminus
Dealer : McGeorge Toyota
imjin's Photo Albums
Last Online: Yesterday 03:20 PM
imjin will become famous soon enough.
Makes sense to me. Do limit straps help prevent this at all?
Mods: Mickey Thompson Classic II | Cornfed 2.5" Lift | Differential Drop Spacers | 930 Inner CV Boots | ProtechEZLift Limit Straps | Spintech Sportsman XL Muffler | Brembo Front Brake Rotors | A.R.E. Z-Series Cap w/ Thule Rack | Stubbs Rock Sliders | Hellwig Anti-Sway Bar | 285/75/16 BFG All Terrain TA KO's | VIAIR 400C Air Compressor w/ 2.5 gal tank | Front clear corner lamps | Odyssey PC1700T battery | Optima Red Top 75/35 battery (backup starter) | Hellroaring 95300A Isolator/Combiner | Truspeed Calibrator
Old 05-20-2008, 10:42 AM
apimpdad's Avatar
2002 Toyota Tundra
Hope this helps.
Thank you. Makes sense now.
Build Thread-
SAS on 02 Tundra
Old 05-20-2008, 11:28 PM
Imdone's Avatar
They can as long as they are set to the correct length. You would have to droop out and check legths and where the ball joints are hitting the cups.
It is still better to spend the money to get a worth while setup instead of a cheap lift so you don't have to add unnecessary parts.
Work in progress...
Old 05-21-2008, 07:01 AM
imjin's Avatar
Defiant ut Terminus
...It is still better to spend the money to get a worth while setup instead of a cheap lift so you don't have to add unnecessary parts.
Yes yes I know that. I'm in that camp too.
Old 05-21-2008, 12:29 PM
Dealer : Toyota West
gipperkid's Photo Albums
Last Online: Yesterday 05:14 PM
gipperkid is on a distinguished road.
In reference to the Bilstein 5100s. Which style is more preferred? The true adjustable coil over style or the strut with adjustable c-clip? Pros vs. Cons of each?
Old 05-27-2008, 08:03 PM
Dealer : Hamer Toyota
2005 Toyota Tundra
climberpm's Photo Albums
Last Online: 10-15-2008 03:15 PM
climberpm is on a distinguished road.
Great post and pics on ball joints and spacer lifts! I'm the unfortunate owner of an 05 Tundra DC who went the cheap route. I installed a ReadyLift 3" spacer lift and have since, within a year, replaced one BJ and see another appears to have failed now also. What do you recommend as the best way out of this predicament? I'm not sure I want to(read:am allowed!) spend the $$$ for a coilover replacement like a SAW. Short of the SAWs do you think I'd be better off with the Bilstein adjustable or the uni-ball UCAs to cure my BJ woes?
THanks!!!
'05 DC 4WD
3" ReadyLift w/285/70x17 on MotoMetal 951s
Old 05-28-2008, 01:23 AM
Imdone's Avatar
The bils will stay within stock lengths to keep you from binding UBJs. That is the cheapest way out of a spacer lift.
Just tell the wife that the "ONLY" way out is the SAWs or ICONs otherwise you could loose a balljoint on the highway and kill yourself and anyone else around you and their dog and their grandmother and grandfather and auntie and uncle and brother, etc... That way if she doesn't care about you maybe one of the other words will strike a cord that touches her heart and then she won't be able to say anything but, YOU BETTER BUY THEM TODAY!!!
Work in progress...
Old 05-28-2008, 07:01 PM
2005 Toyota Tundra
I like the way you think Imdone!!
'05 DC 4WD
