Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Suspension & Axle
Old 06-14-2008, 06:39 PM
ctw41's Avatar
Dealer : Lighthouse Toyota Scion
2000 Toyota Tundra Limited 4WD,
- Other - 07 Jayco Motorcoach
Last Online: 03-13-2010 01:30 PM
ctw41 may have some regrets.
ctw41's Photo Albums
Default Manual hubs without all the extras?
I want to put manual hubs on my "new" 4WD 2000 Tundra Limited but I don't intend to lift it or do a lot of extreme offroading. I read an article @ OffRoad .com ( Replacing Toyota Auto Hubs - Trucks 4x4 @ Off-Road.com )that said the hubs were just a bolt on. Is this only for older trucks? The truck is currently all stock except nerf bars.
I contacted a local toyota dealer's parts department about buying hubs and they told me they were not available even as a dealer option.
If the only way to do this is to change the axle, bearings, cv joint etc.. It appears from all the posts that ORS has the best conversion out there. Any comments?
Old 06-15-2008, 02:24 PM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: Yesterday 08:06 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
Default Re: Manual hubs without all the extras?
Yes, ORS has the complete kit. You need new half shafts but retain the inner CVs and then everything changes from the Inner CV outward. ORS provides all this in their kit. I had the ORS kit on my 00. I had no complaints.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, TIMBREN, HYPERTECH
Old 06-15-2008, 05:24 PM
ctw41's Avatar
So there is no way to do this without changing the axle and outer CV Joint? Are those new outer CV joints available anywhere besides ORS? I'm guessing they are no longer "stock".
Old 06-15-2008, 11:58 PM
Imdone's Avatar
Images: 23
Downey has a kit but the ORS kit is more complete.
No there is no other way other than getting a kit from ORS or Downey. Toyota does not provide any OE parts for Tundras to convert to manual hubs and to my knowledge the previous years Tacos do not fit.
Old 06-16-2008, 06:46 AM
ctw41's Avatar
Looks like I'll be ordering the ORS kit. Thanks for the info.
Old 06-25-2008, 09:58 PM
Dealer : Lancaster Toyota
Last Online: 03-03-2010 12:35 PM
boosted3g may have some regrets.
boosted3g's Photo Albums
Does this kit give you new center caps so you can run stock wheels. I want to do this but dont want to give up my daily driver look. You would think with gas prices and mpg wars this would be a factory item.
Old 06-25-2008, 10:23 PM
Imdone's Avatar
Images: 23
No, there are no center caps, you run centercapless in the front. You can still use the stock wheels, you just don't use the caps anymore.
Old 06-28-2008, 06:55 PM
ctw41's Avatar
My plan is to procure two knuckles, replace the upper ball joint and pre-assemble the "new" ORS manual hub knuckle prior to taking my truck apart. The lift I'm using and the press are not co-located so I'm spending an extra $150 for a couple od used knuckles. I plan on using a hole saw to cut out the center of the plastic wheel covers for the front.
